Results 1 to 10 of 10
Thread: Motherboard fan noise in speakers
    Constant Bitrate JayKaye's Avatar
    Jan 2004
    Sydney, Australia
    Arrow Motherboard fan noise in speakers
    Hi all,
    I can hear the whirring of my CPU fan through my speakers. I thought it may be something else in the car but the same sound is coming through the TV speakers when I plug the machine into my TV at home.
    I have grounded the case in the car with a fairly decent sized cable, however I didnt think this would work considering the sound is also being heard at home through the TV speakers.
    Any help on this one pls?
    Jan 2004
    Sydney, Australia
    any thoughts on this one?
    Maximum Bitrate owenjh's Avatar
    Nov 2003
    NC
    I don't know too much about it, but if you can try another fan, or get one of those zalman coolers that dont require a fan. That could be an idea, or just try another fan.
    CarComputer Status: New Car & Broken (Motherboard Fried)
    Owen JH | My Linux Blog | The Tech Fellows
    Dec 2003
    Canada
    Try an external sound card.
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Are you using DC-DC or an Inverter?
    Either way try powering the fan from somewhere else. If it is connected to a MB header try a molex one instread or from the 12 volt line to the DC-DC/inverter.
    luck
    TruckinMP3
    Read the FAQ!
    May 2003
    UK
    try another fan? maybe yours is faulty?
    ( does unplugging fan fix problem )
    www.digital-car.co.uk - The UK CarPC Forum
    Jan 2004
    Sydney, Australia
    im running a DC-DC. ill try running the fan from another power source.
    the fan isnt faulty, its a brand new one.
    im looking to buy an external sound card, but dont have the money as yet
    May 2003
    UK
    ive had many a faulty new fan - if the suppresion inside isn't correctly fitted it will cause you no end of problems...
    James
    Nov 2003
    Seattle, WA, USA
    I don't think it is your fan. One easy way to check is to put your finger on the center of the fan and alter the rotation speed slightly by breaking it with your finger. Does the pitch of the sound change when you do that? If it does, then it is your fan. If, not then you have other things going on.
    Oh yeah: Be carefull. Count your fingers before and after the test
    Jan 2004
    Sydney, Australia
    Quote Originally Posted by NewTechFool
    Thnx for the tip
    Ill do that and see what happens. Ill post results here.
  1. power supply buzzing help thing i found... read if u have noise
    By TimW in forum General Hardware Discussion
    Last Post: 02-25-2012, 12:48 PM
  2. Hard disk interference noise. (long)
    By MikeHunt79 in forum General Hardware Discussion
    Last Post: 12-27-2008, 07:56 PM
  3. FS: Casetronics C134 and EPIA M9000 Motherboard
    By jusatry in forum Classified Archive
    Last Post: 05-17-2004, 05:38 PM
  4. Case fan modified. Safe?
    By cafn8 in forum Off Topic
    Last Post: 03-18-2004, 11:57 AM
  5. Funny noise coming out of speakers...
    By SuperMatty in forum General Hardware Discussion
    Last Post: 03-17-2002, 11:01 AM
