Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 41
Thread: CarPC sound through car speakers without a headunit?, how?
  1. #31
    Feb 2004
    The mini-phone jack (on the back of your computer) is stereo. The y-splitter will split it into 2 RCA connectors, one for the left channle, one for the right channel.
  2. #32
    Low Bitrate NorthGaVigor's Avatar
    Tenneessee
    Quote Originally Posted by hifiguy
    yep, i know what you are saying. i talked to a car audio friend and his only warning for hooking up the amps and pc to turn on together was the following: make sure the pc is on before the amps turn on. reason being that if the amps are on, and then they receive a signal telling them to turn on again, the sound will be distorted.
    any thoughts on this? wire a seperate on/off switch?
    Huh??? Chicken or Egg?? If you wire the remote turn-on lead (which is the same thing that your power antenna has) to the +12V (yellow) on the PC molex connector then it will ONLY turn ON when the PC is on! PC goes off, +12V goes off, Remote turn-on lead goes off! Simple! If you have any questions don't hesitate to ask. That's the only way you'll learn!
    I've been installing stereo systems for money since i was a freshman in high school. We all start somewhere!
    See attached NOT FINISHED wiring diagram.
  3. #33
    Feb 2004
    Los Angeles
    I decided to use seperate switches for the PC and amps, that way I can power on the the PC first, allow the soundcard to pop, then turn on both amps simultaneously.
    Here's my first version of the electrical diagram w/o fuses:
  4. #34
    May 2004
    Quote Originally Posted by raypsaliga
    you could wire the on/off line of the amp to the 12v rail of the computer psu, that way it shuts down with the computer.
    or run it to the accessory circuit that cuts on with the car. either way will work.
    EDIT: totally missed pages 2 and 3, this has already been mentioned.
  5. #35
    Low Bitrate cyber's Avatar
    Jun 2004
    Frozen Tundra
    delete this post please
  6. #36
    Constant Bitrate Sharkbite86's Avatar
    Apr 2006
    California
    Ok (resurrecting a dead thread here), i am using an external sound card and a few amps to power my system. The only problem i have is that i cant control anything. I can control things like volume, EQ, L-R balence, fader ect. from the software on my computer but i wanted a hardware solution. I dont like the idea of software controlling my audio system. I have seen various pre-amp/crossovers/EQ indash head units and only take up 1/2 din and they are exactly what i want in terms of control. However, they only provide 2 inputs, and i will require 4-6 inputs and outputs. Anyone have any options? Even DIY build it yourself kits would work for me.
    EDIT: an example of what i was thinking about would be the three.1 EQ thing http://www.mobileaudiocontrol.com/pr...50&l1=5250&l2=
    But like i said it only has 2 input (has 6 output though...)
    MacCar progress:
    Planning:-----> [||||||||||||||||||||] 70%
    Parts:---------> [||||||||||||||||||||] 0%
    Construction:-> [||||||||||||||||||||] 0%
    Car broken into... progress is basically zip...
  7. #37
    _
    Mar 2004
    Little Elm, Texas
    just so I understand your set-up a bit more
    why do you need 6 inputs?
    how are you set up that it requires this?
    Jan Bennett
  8. #38
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by Red GTi VR6
    yeah... i assume you want to have 6 inputs to perserve dolby digital/dts?
    your best solution in this case would be the alpine pxa-h700 or 701 digital input with all the outputs you are asking for
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  9. #39
    Apr 2006
    California
    well as scott said i wanted to preserve all the channels im using. I will basically have a 4.1 system in my car. I am planning on installing a mac mini in my car and i was going to connect a Griffin firewave to it to get better surround sound (front LR, back LR, sub).
    So it goes:
    mac mini----->Firewave-----(front LR, back LR, sub)----->volume, bass, treble, LR balence, EQ controls------>Amps----->speakers and sub
    I probably do not need most of the stuff there. All i really need is volume and balance controls (the sub control i can hack off from the wired remote from a powered amp). The rest i can adjust of the computer. Like i said though some kind of diy kit or plan would work too.
    MacCar progress:
  10. #40
    Jul 2005
    so where do you get a usb soundcard?, this thread got explained allot to me
  1. Sound cards from incarpcs , sacrificing sound quality?
    By skinhead in forum General Hardware Discussion
    Last Post: 09-02-2004, 03:05 AM
  2. Carputer to car speakers - how to??
    By tbird2340 in forum Newbie
    Last Post: 10-30-2003, 02:47 PM
  3. Car with no system..How do I wire the speakers to my MP3 system?
    By fogleroller in forum General Hardware Discussion
    Last Post: 02-14-2002, 03:46 PM
  4. HardDrive SOUND in the speakers !!!!!!!
    By KRyZ in forum General Hardware Discussion
    Last Post: 03-10-2000, 02:19 AM
  5. Can I put Pc speakers on my computer car?
    By prado_sergio in forum General Hardware Discussion
    Last Post: 08-26-1999, 01:11 PM
