I want to get out two sets of left audio and two sets of right ( 2 x 2chan amps )
can I just use a splitter to give the output ? would this overload the epia preamp or cause distortion issues?
James
Printable View
James
just wire both left speakers and both right speakers to your amp, you'll get double the power to your 4 speakers, but the ohms will be cut in half (probably to 2) so check your amplifier's manual to see what the minimum number of ohms is.
He wasn't talking about post-amplification.
^^ You should be fine doing this. The only case where you would run into trouble is if both amps had unusually low input impedances which shouldn't be the case.
