Results 1 to 5 of 5
Thread: Loud noice when turning on CarPC
    May 2004
    I´ve just finished my CarPC projekt. Unfortunately (but not unexpected ), i´ve got a problem. When i´m turning on my CarPC, the speakers makes a loud noice.
    I used the ignition lead to turn on en relay, which turn on both the CarPC and the amps...is this the problem?? What if i used a power-lead from the CarPC to turn on my amp´s? If i could, then i´m sure that CarPC get power before the amps...but would that solve my problem??
    //Andreas
    Maximum Bitrate fantomas's Avatar
    Nov 2003
    CT
    the noise...is it just a pop? or a constant noise?
    rebuilding carpc... kinda..
    May 2004
    Quote Originally Posted by fantomas
    It´s just a "POP". When the CarPC is shutting down, there´s no problem...
    Newbie f150tech's Avatar
    CT
    Jul 2004
    NL, Druten
    Or you could use a smiple switch..
    I have 2 switches. the first turns on the pc, the second my amps..
  1. How2 control CarPC from key fob....
    By NotchbackVW in forum Power Supplies
    Last Post: 09-21-2007, 06:27 PM
  2. CarPC Software Launcher
    By Confused in forum Software & Software Development
    Last Post: 05-01-2004, 01:10 AM
  3. Replies: 1
    Last Post: 04-17-2004, 04:43 AM
  4. noice when using 12V from cig-lighter
    By loscooby in forum Power Supplies
    Last Post: 01-01-2004, 05:06 AM
  5. Replies: 1
    Last Post: 12-31-2003, 01:30 PM
