This is what I've found so far in my research. I am not an expert, just learning like you...
2ohm speakers with draw/suck/pull/consume twice as much power as a 4 ohm.
The standard in car audio is 4 ohm so your headunit is likely 4 ohm and unless specified, assume any amp you look at is only rated for 4 ohm.
To drive the sub you need a amp that is stable at 2 ohm (meaning it can provide enough power to a 2 ohm speaker with overheating or distorting).
I just bought an Alpine MRP-F240 ($250 CDN). It is 4 channels and 2 ohm stable which I think would work for you. In addition, it is physically smaller than most amps - important to me so I could fit it under the seat.
As an advanced topic, the amp is also bridgeable. Which means you can combine 2 channels together to drive one speaker at double the power (but the same ohm/impedance). So you could use channels 1 and 2 for the Inifitys and bridge channel 3 and 4 to drive the sub. However, this more advanced and you can probably get good results without bridging (and leave one channel unused).
For more info:
www.the12volt.com
www.sounddomain.com
LinkBack URL
About LinkBacks
