Results 1 to 5 of 5
Thread: Sony Hu's
    New York
    Sony Hu's
    I was thinking about buying the sony cdx-m8800 or m8805x and i was wondering if XA-300 is needed for the aux input on these hu's. And does anyone own any of these hu's that can give me a quick review on their personal experience with them or with any sony hu's hooked to a carputer. Thanks.
    Constant Bitrate TaylorMade's Avatar
    Nov 2003
    Tampa, FL
    If you do a , you'll find that this question has been asked many times over. I think that the final consensus, as far as Sony goes, is that it may or may not work. I have a 5700 with Aux in and it worked with no mods.
    2008 Ford Expedition EL Ltd
    Carputer yanked from the Jeep and Denali and waiting to be installed in the Ford.
    Maximum Bitrate falconey's Avatar
    Feb 2004
    Atlanta
    Quote Originally Posted by ill_ace
    You can always go to circuit city's website. If they have your model the spec sheet will have a spot AUX. If AUX says yes then you won't need the XA300. If it says no you will need it.
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    I'm using a old cdx700
    with a XA300 aux in addon box..
    I was happy with it until I found out it could do something very special.. now I'm over the moon :-) I used to use the aux in, using normal rca leads, from my lineout to the line in.. then after reading these forums found out that I could use the usb socket on the xa300.. I didnt think would work as I thought I would need drivers.. but hey.. plugged it and and bingo.. digital audio now goes direct into the xa300.. fantastic.. it got rid of the tiny earthing noise I suffered from and it also means running one less wire up the car.. just a vga and usb one now does the trick.. I know there not cheap but i'm very happy with mine. :-) + I have got a sony volume stick thing, so I can control most of the functions from the wheel, hence the location of the HU now :-)
    10/10 for sony :-)
    CdR
    Constant Bitrate spectrrr's Avatar
    Jan 2004
    Dayton, OH / Cambridge, MA
    even better than circuit city, I've found www.crutchfield.com to be hands down the best source of information about a head unit and exactly what it will/wont do.
    looked up both the models you mentioned and both specified "rear" aux input, so your good.
    if it said "optional" then you would have needed an adapter
    2000 Jeep Cherokee
    -CarPC: [_____]50% complete
    -planning done, still need a few parts
    -In-dash motorized VGA is finally out, need $$$
    -Need to replace factory HU
  1. Sony UniLink protocol explained here, can someone?
    By SuperSonic in forum General Hardware Discussion
    Last Post: 06-28-2005, 11:37 AM
  2. Would anyone buy CD Changer/Unilink cable hacks for Sony head units?
    By Ashlawn Kemling in forum Classified Archive
    Last Post: 06-14-2004, 02:55 PM
  3. Replies: 6
    Last Post: 10-19-2002, 11:18 AM
  4. Use my touch screen to control my SONY head unit
    By cproaudio in forum General Hardware Discussion
    Last Post: 10-14-2002, 09:37 AM
  5. How do I get sound into my Sony CDX-M700R?
    By percyt2k in forum General Hardware Discussion
    Last Post: 06-05-2001, 10:17 AM
