Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: What hardware and software would I need to get a true decibel reading of my system???
  1. #11
    Oct 2004
    for the reading to be worth anything the whole end result would need to be calibrated, even if the software is acurate & the mic is good, this is really only good to compare one vehicle or setting to another with the same equiptment....
    it's the calibration that makes the number worth anything....
    most real events use the audiocontrol with an spl pack, higher readings & an spl mic..., or at least they did for years.... not to sure what they use now though...
    I've seen a lot of smaller events that they'll tell you, "oh just add 2 to the number to know the "real" reading"... a lot of meters are not acurate to true readings, but are acurate enough for a side by side comparison...
    if you want true readings you can crudely calibrate it yourself by attending an event with a real meter, & comparing the results to yours...
    that's where the "just add 4 to the number" comes from...
  2. #12
    Jul 2001
    a Termlab would get you what you want and then some.
  3. #13
    FLAC XC-C30's Avatar
    Jun 2006
    Abele, Belgium
    Quote Originally Posted by Shadow View Post
    Xenia & Isabelle, totally in love!
    'T SQiekenkot: VOLVO 740GL 2.3
    CarPC: none at the moment
    CLARION APA4300HX => Fountek NeoCd1.0 + TB W4-1337SD
    CLARION APA4300HX => CSS Trio8
    CLARION APA2100 => Dayton IB385-8
  4. #14
    Low Bitrate Mandos's Avatar
    Sep 2005
    Coralville, IA
    Quote Originally Posted by IC-C30 View Post
    but....$$$$'s what I was going to suggest
    Chris Schempp
    Elemental Designs
    Scion tC in progress
  1. Hardware Monitor Software
    By XxAndyxX in forum Software & Software Development
    Last Post: 04-17-2004, 05:50 PM
  2. A few observations in OS and why I'm now using Windows 2003...
    By Mastiff in forum Software & Software Development
    Last Post: 01-21-2004, 10:11 AM
  3. Replies: 22
    Last Post: 08-13-2001, 02:42 PM
  4. GPS software similar to Mercedes system?
    By Phat Justice in forum Software & Software Development
    Last Post: 08-10-2000, 08:26 PM
