Results 11 to 20 of 27
Thread: 2 ohm speakers available?
  1. #11
    C4M
    C4M is offline
    Maximum Bitrate C4M's Avatar
    Apr 2002
    Sydney, Australia
    Quote Originally Posted by antimatter
    That is some good info. Thanks
    I am still not sold on the 2 ohms but would like to hear them in person. I would love all of the extra power
    Typically, you won't find 2 ohm speakers - you'll take a pair of 4 ohm speakers and run them in parallel so they 'present' a 2 ohm load to the amp.
    So it follows - using 8 ohm speakers, you'll need 4 of them to present a 2 ohm load.
    If you only have the space for a single driver, and are all fired up about 2ohm woofers, then look for a dual voice coil driver - get the idea?
    Here's your next stop on the research trail: http://www.the12volt.com/caraudio/boxcalcs.asp.
    This should be required reading for anyone wanting to DIY a car audio installation. So should this site: http://www.bcae1.com/
    Now - neither of these really answer your original question, which I heard as "What is the sound quality difference between 2 and 4 ohm?".
    I don't proclaim to know the answer, but here's my suspicion/guess/opinion (if you research and find different - tell us!):
    Lower resistance loads are not as accurate and precise as higher resistance loads. This isn't as critical for subs, as they are generally sloppy and inefficient, which is why people typically run significantly larger amps to run them. After all, subs deal with a frequency range between say 20hz and 90hz (depending on your crossover set up), while your front stage deals with say 90hz to 20,000hz.
    Accuracy is much more important in the precise bits that we listen to that usually happens in the mid range and top end. As a result, car audio tends to (but not always) get set up as:
    * Subs - bridging channels or wired in parallel to see a lower impedance
    * Fronts - driven at say 4 ohm.
    This is how my system is currently set up (although it was significantly more complex when I was competing in car audio competitions).
    I suspect that if you haven't had subs before, you'll probably struggle to tell the difference. You'll be too busy grinning and drooling at all that bass!
    Here's the most important thing: You listen to your stereo with your ears - not your eyes, and not a multimeter (and not your cheque-book, but that's another story). Plug them in and listen. If you like it, leave it. Research why you should change it rather than just experimenting. Make sure you know the risks of your experiment if you don't understand. Amps and speakers stop working when the smoke gets out, and it's really hard to put the smoke back in a cooked woofer to make it work again
    There is a lot on the bcae site about why attempting to run everything at 2 om is futile (and sometimes expensive).
    Read the pages on ohms law, and on bridging amplifiers as a starting point.
    C!
    http://carpc.riposte.net
    I reserve all rights in connection to each post I author, without exception.
  2. #12
    He is asking about front and rear speaks, not subs (at least by rear I don't think he means subs).
    Isn't less resistance better?
    If we are talking about the interconnects between things then yes but not necessarily when dealing with amplifiers.
    each speaker will have its own channel so none will be run in parralell. I am just trying to get the most out of my amp. It boasts 100w rms per channel @ 2 ohms and 65w rms per channel @ 4 ohms so it leads me to believe that I should get 2 ohm speakers right?
    Understand something about speakers in that if the amp is rated at some given wattage you aren't delivering that all the time. I think this is largely misunderstood by most people that don't know car audio.
    Each doubling of power results in a a 3db increase in volume with an approximately 10db increase representing double the loudness. So if your speakers produced 90db of sound with 1 watt (commonly referred to as the sensitivy rating) then at 2 watts they produce 93db of sound. This doesn't account for any gain your car will produce because of the enclosed space.
    As we continue this thought experiement keep these values in mind:
    A walkman at full volume will produce approx 100db into your ears.
    The front rows of a rock concert approx. 110db
    The pain threshold begins at 130db
    Continuing at 4W your speaks produce 96db, 8W=99db, 16W = 102db (you are now blasting a walkman in your ears) 32W = 105db and at 64W = 108db you are close to simulating the front row of a rock concert right there in your car. Now, if you wanted 2 ohm speaks and could double to 128W then you would be at 111db (not much more than 108db huh?). Since you are only getting up to 110W then you are coming in near 110db, which isn't much better than 108. This is all assuming you are driving your setup and full volume all the time, which you will be foolish to do so.
    So my point is you don't gain much volume wise (and even then it is only a small fraction of your listening time), but what is the tradeoff? A huge loss in sound quality. Through the entire power range a 2 ohm speaker sounds much worse than a 4ohm speaker if you don't have a great amplifier. Distortion goes up a ton the lower in impedance you go. Again, you don't hear it as much in a sub because of the frequency range but with your high end components this shows up big time as harshness and grittyness.
    You might ask why car audio setups tend towards 4 and 2 ohm components when home speakers tend toward 6s all the way up to 16 and more? To get lots of power into an 8 ohm speaker requires a larger voltage which starts to cost more money because of the switching supply in the amp has to produce these voltages which means more costly transformers, capacitors, etc etc.
  3. #13
    C4M
    C4M is offline
    Apr 2002
    Sydney, Australia
    Quote Originally Posted by MrPerfectionest
    Agreed - but the same principle holds. Having re-read the original question though, and thinking about it, I don't think that I have ever seen a 2 Ohm speaker. Ever. Any one else? (Exclude DVC's for the moment)
    C!
    (Please excuse the snip of the well written essay which actually answered the question)
  4. #14
    Maximum Bitrate falconey's Avatar
    Feb 2004
    Atlanta
    With the 5.1 setup he has I don't think he'll want to run his speakers in parrallel. If he wants two ohms he'll have to find speakers that are so equipped. I have never heard of 2 ohms speakers although someone mentioned it in the thread. I have heard of dual voice call woofers that can be wired to 2 ohms or like explained earlier running the cabin speakers in parallel can yield 2 ohms.
  5. #15
    You guys should trust google more often
    Typically you only find 2 ohm components in the higher end speakers because those that are very serious about competition are the ones that are trying to really drive lots of power through them.
  6. #16
    Clover Grayscale's Avatar
    May 2004
    Arkansas
    hes got a very tiny amp, he needs to get 4 ohm speakers and a bigger amp...that would be less than buying 2 ohm speakers
  7. #17
    Feb 2004
    Atlanta
    I wasn't looking for the speakers so why would I google. Maybe you should have been more specific than you guys. I think everyone knew they were out there, but it was going to come down to price. And personally I think 65watts (if that's rms) to each of the cabin speakers is more than enough power. I don't think he'll be going for another amp because again he has the 5.1 setup.
  8. #18
    Don't get defensive. I forgot this is an international board so maybe you took that the wrong way. Multiple people mentioned they didn't think 2 ohms existed (including yourself) and I for certain knew they did. My point about trusting google was that for everyone that said they didn think 2 ohm components existed it would have taken no more than 1 minute of google searching to find the answer.
  9. #19
    Feb 2004
    Atlanta
    No worries my friend, I'm american and still took it the wrong way. Sorry. What I really meant in my statement is that they weren't commonly mentioned or basically, yeah there out there but no ones mass producing them. I can understand the confusion when I say I've never heard of them. I really haven't heard of them, but I would find it highly unlikely that they don't exist. That's what I meant. I should have been clearer.
  10. #20
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    Thanks for all of conjecture on this topic.
    Falcony is right 800w rms is fine with me as for an amp (no compititions here and I would rather spend money on new cool toys for the carpc) and also he is right about my 5.1 setup and that I will not be running anything in parralel. Also the amp i use has the option to bridge with another equal amp on the subwoofer channel if i ever decide to push a couple of 12"s or 1 15"
    @MrPerfectionest
    Thanks for your comments and wisdom. I am going to have to really reread your posts to get a handle on how you broke everything down. Also i remember searching google to find them ( ) and came up with nothing. How about sharing the search term you used
    @C4M
    Thank you for your well written essay! Although i wasn't refering to subwoofers the info you provided was worth you time in typing.
    I think as for me and my decision for for what speakers to get i will most likly get infinity 4 ohm. I do want a really clear crisp front stage. Also I am not a big fan of purchasing speakers, installing them, listining to them and then removing them to send them back cause they didn't live up tp my expectations. I will try before I buy, which probably isn't possible with the 2 ohm speakers.
  1. Speaker Power Question
    By ssa_whiskey in forum General Hardware Discussion
    Last Post: 08-16-2006, 07:49 PM
  2. which speakers for my OLD bmw??? :confused:
    By thorolf15 in forum General Hardware Discussion
    Last Post: 02-04-2004, 09:22 AM
  3. MBQuart 6.5'' component speakers for sale
    By Mikesz in forum Classified Archive
    Last Post: 12-30-2002, 10:05 AM
  4. What speakers where?
    By DingleBerry in forum General Hardware Discussion
    Last Post: 07-05-2002, 08:34 PM
  5. Replies: 3
    Last Post: 07-30-2001, 09:25 PM
