Not as small, but another soundcard that is of comparable utility (self powered, 5.1, yadda... and comes in a nice case with functional controls, i might add), the phillips aurillium
http://www.dealtime.com/xPO-Philips_...rnal_USB_Sound
For those using 5.1/DTS encoder units such as the Panasonic CY-AC300EX, you should check this out. http://www.platinum-records.com/detail.aspx?ID=6944. Let me know if know of anything compatible. It appears to be the best one I have came across so far. Powered by the 5v on the USB/stereo mic/ toslink out/analog out. Pretty good
car computer rev 5: 8" lilliput and usual suspects
Why not just use the onboard soundcard such as the VIA onboard audio. It has COAX out so all you need is a COAX to OPTICAL convertor. They run like 15 bucks off ebay
i can't speak for the digital quality, but with my grado RS headphones, i can hear quite a bit of difference between the onboard audio and the aurillium or audigy 2 nx on the analogue lines.
I am talking about the digital. 1's and 0's baby
that's what they all say.Originally Posted by antimatter
The units that you see on Ebay are the powered by USB or do the need a external power supply?
Robiewp I am sure that the Phililips sounds nice, but its HUGE man.. It just seems to inconvenient. Where would you put this device? If its in the cabin its taking up space, if its in the boot external controls are useless.Originally Posted by robiewp
The reason I am going with the Transit is becuase of the size, has a stereo mic input (for a Andrea stereo mic), USB powered, line/optical in/outputs, size, self powered, and passed DTS. Most converters seems to only pass 5.1. Yeah I know most people don't care about DTS in the car, but there is a lot of extra information in a DTS broadcast. I have a Panasonic CY-AC300ex on EBAY for $160 that has an optical input and Decodes the DTS signal from the Transit. Works nice. I haven't installed my carpc yet, still bench testing everything, but everything sounds nice.... so far.
There is no USB interface. (spdif)Optical on one end and (spdif)coax on the other with a six volt ac adapter. I just went and bought one of those 12v to 6v adapters at radioshackOriginally Posted by mp31023
So if you did have the converter you have now, and you had the choice between the one you have now and the transit, you would still stay with the one you have?Originally Posted by antimatter
Does the converter you bought on EBAY pass DTS to your AC300ex?
