Page 5 of 5 FirstFirst 12345
Results 41 to 50 of 50
Thread: Radio Xtreme Installed and Reviewed
  1. #41
    Variable Bitrate Batmanatthenewb's Avatar
    Sep 2003
    Newark, Ohio
    Quote Originally Posted by wkolodny
    So are you saying the amplifiers dont make any difference?
    Amps did make a difference. What I found was that:
    1) the antenna that came with Radio Extreme was OK.
    2) When I connected the car fm to radio it was almost OK. Lots of static and
    didn't pick up the stronger stations my head unit would.
    3) When I installed the 10db Radio Shack amp, reception improved.
    4) When I installed the 30db Radio Shack amp, reception marginally improved
    over the 10db version. Not enough to warrant the $69 cost.
    5) When I hooked the 10db amp to the Radio extreme antenna, it didn't work
    6) When I attached an after market (auto zone) amplified antenna to the radio
    it was not as good as the stock antenna with the 30db amp.
    7) I read in another post somewhere (yes, I did search in another
    forum ) that for the radio you need to use the 58 series coax. It is better
    shielded and is designed for fm radio. My coax is the 60 series. The coax
    is used in the adpter from the antenna plug - to coax - to 1/8" plug. I am
    thinking this is my biggest leakage. Gonna try to round up a foot or so of
    the 58 series and see if that helps.
    8) Still gonna try attaching the XM antenna. If that doesn't do it, then I am
    convinced it's just the radio unit. I've tried multiple antennas, multiple amps
    shorter cable lengths, powered antennas, un-powered antennas, even
    consulted with executive project suppervisor of my car Mr Bud Weiser.
    thepogcbr900rr,
    Not going to XM, just gonna try to attach the antenna to the Radio Extreme.
    Batman
  2. #42
    Oct 2003
    Quote Originally Posted by Batmanatthenewb
    I am actually in the process of trying to adapt an XM receiver to the Radio Extreme. They sat the antenna is very good, I could have the shorter cable, and maybe it will work. I'll keep you informed.
    Batman
    The XM antenna will NOT work.
    XM is a totally different type of signal from standard FM radio.
    Also, XM antennas are NOT a passive. The XM receiver sends a small amount of power up the wire to the amplifier/converter in the antenna. Without being powered correctly the antenna will not work.
    XM is in the 2.6Ghz freq. range, the antenna is designed and tuned for this frequency range. It will not pickup a signal at 88-107Mhz.
    And shortening or adding to the cable could cause it to no longer work with a XM receiver. This is espcially true when adding to the cable. This is why XM antenna extension cables have a built in powered amplifier.
  3. #43
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    Damn... why dont they make a high quality USB AM/FM Radio
  4. #44
    Variable Bitrate wkolodny's Avatar
    DC
    Installed an amp. Results are here:
    My 2001 Sport Trac Install
    Don't Fear The Gurkey
    Click here to check out My Setup
  5. #45
    Top Ramen lgbr's Avatar
    Feb 2004
    Spokane, WA, US
    Wow, that sounds great. I might try doing that.
    Audio Rockford Fosgate: 900 Watt 4-channel amp, 501bd Mono amp
    Computer AMD 2400+ XP, 1 GB DDR RAM, Orbit Micro 250W DC-DC PSU
    Head units are for cheaters!
    sure some girls fake orgasms.....but it's guys like me who fake the whole relationship
  6. #46
    Mar 2004
    Montreal, Qc.
    Quote Originally Posted by lgbr
    Will those pick up stations that are not DAB?
    No it will not pick up non DAB stations.
    But like in my area all my stations broadcast DAB.
    VWMAN
    "Live Long And Prosper"
    car: VW Cabriolet '90
    puter: M10000(toasted), Lilliput, CarNetix
    status: In Progress
  7. #47
  8. #48
  9. #49
    IQ < 70
    Mar 2004
    bump
  10. #50
    DC
    wkolodny,
    Are you still happy with the 20db amp now that you have run it a while?
    Batman
    I am quite happy with the Amp. Radio Xtreme is usable with it. Still not anywhere near as good as my head unit's radio. I still have it connected but ended up doing this: My 2001 Sport Trac Install
  1. My 2001 Sport Trac Install
    By wkolodny in forum Show off your project
    Last Post: 01-30-2008, 11:18 AM
