Results 1 to 10 of 16
Thread: What do u use for an amp/head unit ?
    Jun 2004
    Just wondering how u guys route your audio ?
    DO u use the factory head unit ? if so where do u move it.
    Ive been thinking of using the factory head unit with the AUX input.
    This will allow me to keep features like steering wheel controls.
    Just trying to figure out where I would move it to.
    I will need to move my A/C controls down a little to fit the screen.
    Chris Armstrong
    www.ChrisAndNat.com
    Top Ramen lgbr's Avatar
    Feb 2004
    Spokane, WA, US
    I run 3 cables (that's 6 RCAs) to my two amplifiers. I ditched the head unit because the computer plays CDs, stores all my music, and has a nice interface anyway. I went ahead and sold the head unit for cash. Besides, the sound quality is better if you skip the head unit.
    Audio Rockford Fosgate: 900 Watt 4-channel amp, 501bd Mono amp
    Computer AMD 2400+ XP, 1 GB DDR RAM, Orbit Micro 250W DC-DC PSU
    Head units are for cheaters!
    sure some girls fake orgasms.....but it's guys like me who fake the whole relationship
    Jun 2004
    Queens, New York
    how do you route your carputer to the amp?
    Constant Bitrate coachreed's Avatar
    May 2004
    Lee's Summit, MO, USA
    I don't have my carputer up and running yet but can say I will be doing the same as lgbr... I ditched my stocker headunit awhile back and will be running RCA's to the rear for my 6.1 surround sound... total of four amplifiers. No need for a headunit. Just my opinion of course.
    TTYL!
    Coach... aka Randy!
    Jun 2004
    Well I was thinking ditch the head unit and using a computer 5.1 speaker setup.
    Just worried it wont be loud enough.
    Chris Armstrong
    www.ChrisAndNat.com
    Jun 2004
    AZ
    Coachreed. I am very interested in doing the same type of setup. I was going to get a headunit, but now i may not since i will have little room. I am sure this has been answered somewhere else, but can you tell me how you rand the RCA cables from the amps to the Audigy? I am using a Audigy 2 NX external. I am assuming I need a y adapter to link the RCA cables (left and right) to the single inputs of the Audigy.
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    Audigy outputs connect to a Y-Cable that converts to female RCAs. Then use standard male-male RCA cables to hook up to amp. Put your Audigy as close to your amp as possible. This will minimize the cance of you picking up interference in your RCA cables. If you want 2,4,5,6,7 channels then you just need more Y-cables and amplifier channels.
    Jan 2004
    not sure... but u might also want/need a pre-amp/equalizer... so u can easly control the volume and well... the equalizer if u so desire...
    correct me if/where im wrong
    but that would be the easiest way... right?
    AT mobo
    Intel Pentium MMX 233mhz
    ESS Solo PCI soundcard
    Linksys NIC
    Irman
    Mar 2004
    Redondo Beach, CA
    You don't need anything else. If you want external volume control or equalization, then yes, you could also install a preamp with a volume control. You could also buy a POT and a few parts at radio shack and make up your own external volume control, if you want.
    I just use (and trust) the software for volume control. I fully expect a software crash to completely blow out my speakers (and eardrums) one day soon.
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    i use a griffin power mate to control volume it works fine, plus i have a 3 way switch mounted on my dash, i can switch everything in my boot between connected to ignition, straight power, or off, this means i get out of the car at the servo and i can switch it to "on" therefore everything stays on for the time i go and fuel up, this doubles as protection of a major fault, i can switch it to off and my amps will switch off. My computer goes straight to my cadence amps 1x300wRMS for the sub 4x60wRMS for the fronts and rears. Having the extigy box in the boot means i can use short rca's straight to the amps
  1. Can a car-computer replace a stereo head unit?
    By CA 3000GT in forum General Hardware Discussion
    Last Post: 11-13-2006, 09:24 PM
  2. Stock head unit (ford taurus)
    By frostband in forum Car Audio
    Last Post: 12-26-2004, 12:14 AM
  3. Case fan modified. Safe?
    By cafn8 in forum Off Topic
    Last Post: 03-18-2004, 10:57 AM
  4. Slot load dvd in a head unit
    By mp3truckstereo in forum General Hardware Discussion
    Last Post: 09-01-2002, 10:17 PM
  5. car head unit
    By BoneMan in forum General Hardware Discussion
    Last Post: 07-29-1999, 09:30 PM
