Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Softer music?
  1. #11
    Jun 2004
    Bay Area, California
    output is in AC. you can measure it by playing test tones. it should read a different voltage for every frequency. thats how you get companies like clarion posting amplifeirs that can do 1000 watts, when they measure output at 1000 Hz, where its easy to post high numbers, versus high end amplifiers that may be rated at lower or multiple frequencies, that present a more realistic power value.
    regardless, check out the price on the overdrive. its a two channel line driver, I might consider jsut driving the front channels, not the rear. you can always get a second one, if the price of two is less than teh cost of one matrix.
    your second option is to check out some of david navone's products, he makes hte best electronics in his field of production that I personally know of. cant go wrong with navone! I believe the site is www.davidnavone.com, if not, google it, itll be something like that. im pretty sure he has a four channel line driver.
    good luck!
  2. #12
    Low Bitrate philstuf's Avatar
    Jul 2004
    Georgia
    Quote Originally Posted by DJKhan85
    Maybe its just me. But after installing my computer and setting up my audigy 2 nx, my music, even when cranked up all the way, doesn't seem as loud as it used to be. Bass is also lacking a bit. Most songs I can compensate for the bass using cut off frequencies and what not. I was wondering if a preamp after my audigy but before my stock amplifier would yield louder music. Oh by the way I have a stock BOSE system.
    Ah, the WONDERFULL bose sound system...
    What you are looking for to fix this is a devie that will convert your UN-Balanced output from your Audigy to a Balnaced output. Ths Bose amplified systems in cars (that I worked with at least) required a balanced signal input. If you are unfamiliar with balanced audio, here goes: A balanced signal looks like a regular unbalanced signal, but the negative lead (usually the sheild) has the identical signal on it, 180 degrees out of phase. The signals on the negative and positive leads look like mirror images of each other. This is done to eliminate noise getting in the system as the signal travels from the source to the amplifier.
    A line driver might not help you out, unless it has a balanced output, but this is a bit uncommon.
    Check with some of your local GOOD car audio stores. Tell them you want to take a "preamp signal" and send it into your Bose amplified system, and that you know you need a "BALANCED" signal into it.
    Should make all the difference in the world on yours.
    -Phil
    1995 Thunderbird
    Clarion 9375 HU, 2X CDC1255 12 Disc changer, 7500 DSP/EQ/Xover (w/fiber optic interconnects), 7501 TV Tuner/Aux
    Xtant 1001d 1 Ch, 4180c 4 ch
    7" Xenarc VGA touchscreen
    1GHz Via-Nehemiah, 250 GB HDD
    XMPCR w/TOSLink, SB Audigy NX
  3. #13
    Jul 2004
    Georgia
    Quote Originally Posted by falconey
    Get a better amp and that will give you more control over your system believe me. Aftermarket amps can/will give you internal low and high pass crossovers and gains. The gain will allow you to correctly setup the system based on your headunits input level. You would adjust the gain to be suitable to that input level. Basically giving you louder music.
    Don't forget that a lot Bose speakers in cars are 2 ohms (some even 1 ohm). Bose did this to effectively leverage the 12 volt power system and build more powerful amplifiers (36 watts to a 4 ohm speaker, versus 72 wtts for a 2 ohm, if the amp can handle it).
    Most amplifiers are only stable with regular car stereo speakers (usually 4 ohms). If you buy an amp, you may want to see one of your better local car stereo shops prior to purchase and tell them your situation. Most "mom-and-pop" shops would be VERY willing to help you out with info/recommendations. I know if you walked into the shop I used to work at, telling me what you were doing, I would (as well as everyone else I worked with) jump at the chance to help out and see it.
    -Phil
    1995 Thunderbird
  4. #14
    Constant Bitrate DJKhan85's Avatar
    May 2004
    Boston, Mass
    Quote Originally Posted by philstuf
    -Phil
    So I get what Your saying. Would something like this http://www.davidnavone.com/detail.asp?PRODUCT_ID=N-684V
    work for me then?
    EDIT: I just looked up specifications for the audigy 2 nx and it says that it outputs 2volts rms. I read almost a volt in my car when attempting to measure it. DOn't knwo where the other volt went.
    Computer:
    COMPLETE SYSTEM OVERHAUL!!!!!!
    STAY TUNED IN THE UPCOMING WEEKS!
  5. #15
    May 2004
    Boston, Mass
    Did even more on turning an unbalanced signal into a balanced signal. I found a wealth of information which only lead to more questions/problems . Now I saw this product http://www.whirlwindusa.com/pcdi.html
    Now that will turn unbalaced into balanced signals. SO yeah I found a way to do it. BOOOO it uses XLR outputs. I did some more researching on XLR connections. So in a nutshell what I got from it is that 2 of the leads are basically powered. allowing the output voltage to be doubled. Now here lies another one of my problems. Since I can hook my audigy up to that product and get myself From unbalanced to balanced. Connect the LIVE output from that "box" to the positive speaker lead that heads to my bose, and connect the Reference andd Ground to the negative speaker wire heading to my bose. This is what I am interpreting from my google searchs and such. Please tell me if I'm totally nuts and just made that stuff up or if it is somewhat true. Thanks for everyone's help so far!
    Computer:
  6. #16
    Jun 2004
    the audiocontrol overdrive puts out a balenced signal, by flipping a jumper inside teh unit.
  7. #17
    May 2004
    Boston, Mass
    Just got my e-mail back from Audiocontrol regarding the whole balanced unbalanced issue. This is what they said
    "The Matrix will balance the signal at input allowing it to reduce/reject noise. It's output will be unbalanced, but the balanced inputs will reject noise at that point in the signal path.
    At 03:15 PM 7/6/04, you wrote:
    The matrix line driver says it supports balanced audio signals. Now if my source going to the matrix is unbalanced and the matrix is in balanced mode, will the matrix's output be balanced? Thanks for your time."
    SO this leads me right back to square one with a unbalanced signal(but more powerful one) going to my bose if I use the Matrix/Overdrive.
    DAMN YOU BOSE! DAMN YOU!
  8. #18
    Jun 2004
    dang, i guess I was wrong. wel, the overdrive supports balenced inputs too, i guess!
  9. #19
    Jun 2004
    Seems that almost EVERYONE uses a differant sound output device than what exists on their mobo. I'm planning on doing it myself just because I want the best SQ possible, even if that means sacrificing SPL and or my next months mortgage
    Has anyone had a GOOD experience with the onboard sound from the mini-itx boards? UPS still has all my equipment so I haven't had a chance to test it out for myself.
  10. #20
    May 2004
    Boston, Mass
    onboard= no no for good sound. Also it was easier to run a usb cable thats in my glove box to my center dash hub that it would be for me to run 4 cables from my trunk to my center dash. If you want good quality sound then replace everything audio wise in your car.
    Computer:
  1. Replies: 9
    Last Post: 09-29-2003, 01:21 PM
  2. 4am MUSIC Console 1.5 (music jukebox)
    By OvernightTech in forum Software & Software Development
    Last Post: 09-01-2003, 02:10 PM
  3. Ok. I start music, and flick to the home screen.
    By Skraggy_uk in forum ME Archive
    Last Post: 08-26-2003, 05:01 PM
  4. DISH TV music storage project...
    By claylong in forum General Hardware Discussion
    Last Post: 04-16-2003, 09:08 PM
  5. Opinions & Feedback needed (new music)
    By PianoJay in forum General MP3Car Discussion
    Last Post: 08-18-2000, 06:09 PM
