Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Confused about how to hook up PC -> Amps
  1. #11
    Maximum Bitrate DjBac's Avatar
    Jun 2004
    GREECE/Athens
    What is the best solution for the BEST SOUND QUALITY from a PC!!!???
    My audio setup in the car is:
    4xmid-bass with a 2 channel Zapco
    2xmid-ranges and 2xtweeters with a 4-channel Emphaser
    2xcoanxial for rear with a 2 channel Emphaser
    1x12" sub with a mono ZAPCO!!!
    1 centre channel with an Emphaser!!
    I am gettin Alpine's processor PXA-H900..
    So the whole system will not be passive!!!
    Every speaker with its own channel and crossovered through the processor!!!
    The processor is full 5.1 etc and besides the analog inputs has 2 optical..
    So, my motherboard has a 5.1 soundcard onboard with optical output!!
    Would it be better using a USB or PCI audigy X2 or stick with the onboard one?
    I am asking because all the processing and decode will be done by PXA-H900....
  2. #12
    Jun 2004
    Winnipeg, Canada
    Quote Originally Posted by SoFlaLude
    Not necessarily true - the Shuttle MN31N has onboard video (with 2 VGA ports for dual screens, no less) and the SoundStorm audio processing capability, and is a micro-ATX board so it's nice and compact.
    I don't see any mention of that board on Shuttle's site: http://www.shuttle.com/hq/product/product_m_amd.asp
  3. #13
    Jun 2004
    Winnipeg, Canada
    I was looking at the Audigy 2 NX, and it does 5.1 output through 3 line-outs, by sending front left/right through one, rear left/right through another, and center/sub through the 3rd line-out. If I wanted to send the sub channel to my sub amp how would I get rid of the center? If I used a y-adapter to convert the 1/8" line-out jack to dual RCA's can I just plug one of the RCA's into my sub amp?
  4. #14
    Newbie jaymuzzy's Avatar
    Jun 2004
    Sierra Vista, Az USA
    I just posted this item on another thread, but it seems appropriate to mention it here too. If your going for quality sound, you really should be running your connections out of the computer through this device first, then to your amps. Take a look around on the audiocontrol site, they have some other great in-dash devices.
    http://www.audiocontrol.com/MobileAu...sh/Three1.html
    http://www.audiocontrol.com/MobileAu...rs/Matrix.html
  5. #15
    Jun 2004
    GREECE/Athens
    What about my post??
    I think with the Apline's processor would be OK!!!
    My question is, if I use optical output does it matter if it is onboard, PCI or USB???
    Will I have ANY noise??
  1. Connecting two amps to PC
    By Hoopstar in forum General Hardware Discussion
    Last Post: 06-24-2004, 06:47 PM
  2. PC -> Amp and HU - Amp question
    By Nokia6600 in forum Newbie
    Last Post: 03-24-2004, 05:42 AM
  3. PC > AMP
    By sss-610 in forum Newbie
    Last Post: 01-28-2004, 03:07 PM
  4. How to hook up a Car PC?
    By XxAndyxX in forum General Hardware Discussion
    Last Post: 01-11-2004, 10:31 PM
  5. Will these PCMCIA -> PCI adapters work with all PC cards?
    By bombboyer in forum General Hardware Discussion
    Last Post: 12-19-2002, 12:46 PM
