Results 1 to 10 of 15
Thread: Confused about how to hook up PC -> Amps
    Jun 2004
    Winnipeg, Canada
    I am planning on using an nForce2 motherboard with onboard sound to drive my system (just the MCP not the upgraded MCP-T sound chip). It has 6channel sound, meaning 3 1/8" plugs in the back. I've been told 1 is front channels, 1 is rear channels, and 1 is center channel. Now when I'm playing MP3's through WinAmp, I believe sound is only going to be coming out of the front channels. In my car I have 4 speakers connected to a 4 channel amp, and 2 subs connected to a mono amp.
    So to properly hook this up would I need to split the front channel output from the PC into 3 separate lines so I can run 2 to the 4 channel amp, and 1 to the sub amp. If I do this would the signal still be strong enough to maintain a good sound quality? Is there a better way to do this that I am overlooking?
    May 2004
    Why not use the front-channel on your soundcard as inputs to the front channels on your amp, the rear channel on your soundcard as input to the rear channels on your amp, and use a crossover on one either the rears or the fronts (preferably the fronts) as input for you sub amp?
    You will lose your center channel output, but unless you have a speaker in your dash it's not worth much anyway. This way, you can still use most of the sound effects from your soundcard (left-to-right balance, forward and rear fade, custom 3d effects, etc.).
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    the way you said optikal would work fine, i use the rear speaker out to go to my rear speakers and the front speaker out to go to my front speaker and the sub amp (i just use the filter on my amps so i dont see any need for a crossover). Depending on how the soundcard is setup it may not put any sound to the rear channels like you said, if you want to change this there may be an option in your sound card settings otherwise if you use winamp there are upmixing output plugins. Or if you are happy to split each signal 3 ways that would work fine, it just means lots of adaptors
    Top Ramen lgbr's Avatar
    Feb 2004
    Spokane, WA, US
    Do you have the right drivers installed? There should be a program that comes with it so you can set up so that you have one plug for front speakers, one for rear, and the last one for LFE (Low frequency enchantment, for subs).
    Audio Rockford Fosgate: 900 Watt 4-channel amp, 501bd Mono amp
    Computer AMD 2400+ XP, 1 GB DDR RAM, Orbit Micro 250W DC-DC PSU
    Head units are for cheaters!
    sure some girls fake orgasms.....but it's guys like me who fake the whole relationship
    Jun 2004
    Winnipeg, Canada
    I haven't bought it yet. But my understanding was, that although there are 3 plugs, when playing a 2 channel source (such as MP3's through WinAMP), only the front channel plug is outputting any sound.
    It sounds like it may be possible to change this through either sound card driver settings, or through a WinAmp plugin. Can anybody else confirm this, or elaborate?
    pip
    pip is offline
    Maximum Bitrate pip's Avatar
    Mar 2004
    Parker, CO
    There is probably a BIOS setting too, you'll need to set that & install drivers I should think.
    May 2004
    Can you get it to put the bass on its own channel, if I wanted to put my subs on their own separate channel on the sound card?
    Maximum Bitrate starfox's Avatar
    May 2002
    Australia
    I think you need the APU to do any sort of DSP effects with an nForce. If you have the MCP, you just have a 6 channel sound card with no ability to reroute sound or apply effects (eg. virtual LFE channel). You need a program that'll send a 6 channel output to the soundcard (like powerdvd).
    You can parallel as many lines as you want off the line out from a soundcard, and it shouldn't affect the sound quality as long as your devices don't introduce noise into the signal and they aren't power drains.
    Jun 2004
    Winnipeg, Canada
    Quote Originally Posted by starfox
    That's exactly what I was looking for, thanks.
    Upon further investigation, it appears that when getting an nForce2 motherboard you can get either the good onboard sound (APU + SoundForce) or onboard video, but not both (when you get the onboard video version it comes with different onboard sound via a RealTek chip). So now I'm torn between which board to buy.
    If PowerDVD can output sound to all 6 channels, then it should be possible for a WinAMP plugin to do the same thing via a plugin (as mentioned by Nic). I will have to investigate this further.
    Jan 2004
    Not necessarily true - the Shuttle MN31N has onboard video (with 2 VGA ports for dual screens, no less) and the SoundStorm audio processing capability, and is a micro-ATX board so it's nice and compact.
  1. Connecting two amps to PC
    By Hoopstar in forum General Hardware Discussion
    Last Post: 06-24-2004, 06:47 PM
  2. PC -> Amp and HU - Amp question
    By Nokia6600 in forum Newbie
    Last Post: 03-24-2004, 05:42 AM
  3. PC > AMP
    By sss-610 in forum Newbie
    Last Post: 01-28-2004, 03:07 PM
  4. How to hook up a Car PC?
    By XxAndyxX in forum General Hardware Discussion
    Last Post: 01-11-2004, 10:31 PM
  5. Will these PCMCIA -> PCI adapters work with all PC cards?
    By bombboyer in forum General Hardware Discussion
    Last Post: 12-19-2002, 12:46 PM
