Results 1 to 10 of 15
Thread: Thump noise on epia bootup
    Oct 2003
    Copenhagen, Denmark
    Hi There
    When i turn on my pc in the car (epia800) it sends out two distinct noises one short bump/thump kinda noise and one right after, sorta crackling. i have no generator noise when the system is running, so i am kinda lost for solutions. Can i put something on the audio out from the epia to stop these noises ?
    Also if i want to use the spdif digital out what would be a cheap/medium priced starter amp to use ?
    Jan
    Nov 2003
    Marietta, GA
    Dope,
    Most CarPC's will send out a "thump" when they're powered on, if the audio amp is already powered up. The best way to avoid the thump is to delay turning on your auidio amp until after your CarPC is powered up.
    MikeH
    Constant Bitrate b_nom's Avatar
    Houston, TX
    Yeah, my epia does that too
    '96 Chevy Cavalier - EPIA M10000, Win2K,MediaCar, Deluo GPS Mouse with Routis, 60GB external HD, 7" widescreen monitor from DigitalWW.
    '00 Jeep Wrangler - planning stage
    What can BROWN do for you?
    Oct 2003
    Copenhagen, Denmark
    Doh, what if i was to attach a usb or another pci sound card, would it do the same ?
    Jan
    Maximum Bitrate more mods's Avatar
    May 2003
    Atlanta, Ga.
    I use Creative USB on my EPIA 800.
    It thumps and cracks too.
    Nov 2003
    Marietta, GA
    I would guess the USB may work better if the USB hub stays powered when your CarPC is turned off/on. As for the PCI card, sicne it gets power from the CarPC, it will probably thump too.
    The only good way to get rid of the thump is to add a few seconds of delay to the RemoteOn signal that feeds your audio amp or head unit.... This way, the sound card's output has settled out before your amp amplifies it.
    MikeH
    Variable Bitrate no1knows's Avatar
    Feb 2004
    Guildford, Surrey, UK
    Just stick a relay, triggered by your power supplies 12v, in between the sound out and amp. Just splice the RCA cable and cut the positive as the switched.
    Mods: 18" Boss rims,Twin custom stainless exhaust,cold air induction.
    Sound: Pioneer 7400 HU & 6x9's,12" Vibe Sub,600W Kenwood amp.
    CarPC: MicroATX, Inverter, WinTV, Lilliput 7", USB GPS
    http://www.no1knows.com/galleries/
    Oct 2003
    I solved that problem with a relay from davidnavone.com. It turns my amp on a few seconds after the Epia comes out of sleep.
    May 2003
    Atlanta, Ga.
    Quote Originally Posted by MikeH
    My USB is powered all the time, and it thumps and cracks.
    The relay would proably work thou.
    May 2003
    Atlanta, Ga.
    Quote Originally Posted by Alric
    What model # did you get?
  1. Noise on audio from laptop
    By pip in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 11-24-2006, 08:09 PM
  2. Replies: 86
    Last Post: 04-04-2005, 04:57 PM
  3. Damn Noise
    By Freeman in forum General Hardware Discussion
    Last Post: 03-20-2004, 01:37 AM
  4. Original Epia VS Epia M
    By MeanGT in forum General Hardware Discussion
    Last Post: 09-23-2003, 04:25 PM
  5. need some noise help
    By spyhunter in forum General MP3Car Discussion
    Last Post: 07-20-2003, 11:20 PM
