Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: building a speakerbox, question?
  1. #11
    Jun 2004
    Quote Originally Posted by 14.4vTech
    GLUE!?!?! Never GLUE anything, What and why do you want to glue.
    the peace i had was about 3'x2' it was about $60.
    Look for a plastics or glass place in the phone book call around and some pne will point to the right phone number.
    when i say glue i actually mean fuse, seal, attach.. ya know? If I screwed them together that's fine but i still wanted to use something stronger than silicon seal to seal the seams.
  2. #12
    Jun 2004
    Quote Originally Posted by tsparks
    Ohh, k no just use sillicon its better because it doesnt dry hard, use elmers in between the wood peaces when your scrweing it together. (suggest drilling and screwing the box together first just to make sure its all right, then take apart and glue. when your done if your still paranoid about air leaks you can use liquid nails inside the box on all the seams.
  3. #13
    Jun 2004
    Upstate New York
    Personally I'd screw it all together and seal all the seams with clear silicone caulk. When it's done fill it with water and see if it leaks. If it does drain it out let it dry and reseal where it leaked. Should work out fine. Liquid nails should also work pretty well if you want it glued as well as screwed. Certainly would be strong seams.
  4. #14
    Jun 2004
    Bay Area, California
    good luck finding 3/4 inch plexi fora rerasonable price. the stuff is prohibitively expensive. My piece of plexi one inch thick, dimensions 7x48 cost nearly $100 retail. and that is just one piece!
    realistically, lexan or plexi are indeed stronger, or at least have hte potential to be stronger than MDF. However, they flex much much more easily, and its very difficult to add bracing to teh box, at least mroe so than MDF, and still look good.
    thus, its mch more often that you will find plexi enclosures that flex, contributing ot ****poor sounds. Ive never personally heard an all plexy box htat has sounded good yet. this could be for a myriad of reasons, but Its really just too cost prohibitive to work with.
    my vote for assembly, should you choose it to work with, is to use the adhesive that breaks apart the chains and repolymerizes the acrylic at the joint. It becomes stronger than the bulk material, so it will be strong and doesnt even require sealing on the inside, where you could see whatever you used.
    also no screws required!
  5. #15
    Mar 2004
    Quote Originally Posted by Cris
    How did you calculate the volume?
    This is cool freeware app.
    WinISD/WinISD Pro from http://www.linearteam.dk/
  6. #16
    Jun 2004
    should be www.linearteam.org for those of us in the states
  1. Newb question about standard psu's
    By newbiemcnewb in forum Power Supplies
    Last Post: 06-06-2004, 11:05 AM
  2. DVD drive question
    By Pokey in forum Newbie
    Last Post: 05-11-2004, 05:26 PM
  3. Building regulator/shutdown controller question
    By djrkd in forum Power Supplies
    Last Post: 11-02-2003, 06:17 PM
  4. Building Sproggy's PSU, PCB question....
    By adder in forum Power Supplies
    Last Post: 11-09-2001, 05:34 AM
  5. Is this a stupid question??
    By Raymond in forum Power Supplies
    Last Post: 05-23-2001, 01:01 PM
