Find out if your place where you're showing has 110VAC power outlets accessible to you... then you just need to hook up a small, but beefy, battery charger and you should be ok.![]()
I am planning on putting my Integra in the Hot Import Nights show in Boston, MA on July 17th. It is at the Bayside Expo Center, and having been there I know it is indoors. I was wondering, how can I run my stereo, neon lights, strobes, etc. for a good portion of the show (3-5 hours) without draining my battery. For a little background, my stereo is about 2500 watts RMS (yes I know this is right), plus a 750 watt power inverter for a carputer and other lighting, and about 16 neon tubes and strobes. I have an Optima primary battery, as well as a yellow top secondary battery, 5 farad capacitor, and 200 amp alternator. Even with this, I was told that I can probably have my stereo, light, etc. on for about 45 minutes - 1 hour before the secondary battery is drained (which I don't want to do). So if anyone knows a solution, please help me. I doubt that I will be able to start my car periodically to rejuice the batteries because it's indoors, but there has to be a way, since I've been to many shows before and seen cars w/ systems blaring and tons of lights on. Any help would be greatly appreciated.
Looking to buy or sell a home in Southeastern CT?
Click here: timfrederick.prudentialct.com
2003 Toyota Camry V6
Kenwood Excelon 790 HU, VIA C7 + M2-ATX, Xenarc 700TSV, and 5 discreetly installed amps.
what kind of battery charger do you mean? i have one of those emergency units w/ jumper cables, which plugs into the wall. i know i can get an ac outlet at the show, i just don't know how to go about hooking up a charger or whatever it is i would need, and that can handle the massive power consumption
You can ditch the batterys from the show, and use A/C power.. but you need a freakin large power supply to convert to the high wattage. Buy 15 of these and you'll be set.. the show people might not like you though.. better bring a generator:
http://www.buy.com/retail/product_jump.asp?sku=10342701
Don't run your 2500 watt system.. and you should be fine running your lights, and computer, and maybe the system on low or partial power.
u will need something like this
http://www.sears.com/sr/javasr/produ...id=02871224000
or http://www.sears.com/sr/javasr/produ...id=02871232000
but u have to see if bayside allows u to use their power supply. if not mstaken u have to pay extra for that. dunno
Best Technique In Life Is Having No Technique
ONE DAY I WILL LEARN HOW TO USE THE COMPUTER THE RIGHT WAY.
jeeez, theres no way u can run 2.5KW of ICE, no point either. just run the neons and carPC off a 12v PSU, battery charger may work, but u might blow it, those arent mean to supply much wattage, theyre designed for trickle charging.
If you do show off your ICE, ull need the engine running, and even then you might be in trouble, 200A x 12 = 2400W lower than yr ICE install alone, suppose you might not need it for long so yr second battery could help out, and the ICE probably wont be 2500W all the time.
If your in luck they might give u 12V power lines, but they certainly wont want yr ice running off them.
Mods: 18" Boss rims,Twin custom stainless exhaust,cold air induction.
Sound: Pioneer 7400 HU & 6x9's,12" Vibe Sub,600W Kenwood amp.
CarPC: MicroATX, Inverter, WinTV, Lilliput 7", USB GPS
http://www.no1knows.com/galleries/
CAR show, not audio show, so just have all your bling polished up, and the carputer playin some fast and furious![]()
well, i am going to install switches to the remote turn on's to the sub amps, so i can just have one amp running two subs (600 watts total). i know they offer ac outlets for $45. i definitely want the carputer running and all neons and strobes. i could probably get away with like a 150 amp power supply or something. all depends. i don't even know how i would hook up the power supply, because i have the strobes and neons running off my primary battery and the stereo running of my secondary. plus, i guess you aren't even allowed to have the battery hooked up during the show. i don't know, will figure something out. thanks for the help
Yeah they want you to pay to use their power, and they don't want to have a lot of people getting jumps in order to leave the show.
I work at a parts store, and I ended up selling an AC-DC converter to him because he said he wasn't allowed to have his battery hooked up to the car while it was inside. I guess they don't want any battery explosions or whatever.
You might want to double-check the regulations before you buy anything.
Anyway, good luck at the show! Representin' the MP3Car clique!
Regards,
Kris
