Results 1 to 3 of 3
Thread: ariel to rca
    May 2004
    ariel to rca
    i currently have an asus terminator case with a built in radio tuner
    it came with an ariel antenna that has an rca input, is it possible to connect my ariel to the pc with a sort of convertor?
    the ports are obviously different
    see pic, it will probs make more sense! lol
    http://server6.uploadit.org/files/Azh2004-help.JPG
    Low Bitrate philstuf's Avatar
    Jul 2004
    Georgia
    Quote Originally Posted by Azh2004
    Looks like you are in for a trip to your local Radio Shack for a soldering iron
    I have never seen a Car "motorola" styla antenna to RCA adapter. BUT.....
    You could get an "Antenna Extension" cable (whatever length fits your needs), hack of the end you do not need, and the solder it to an RCA plug. Should do the trick.
    -Phil
    1995 Thunderbird
    Clarion 9375 HU, 2X CDC1255 12 Disc changer, 7500 DSP/EQ/Xover (w/fiber optic interconnects), 7501 TV Tuner/Aux
    Xtant 1001d 1 Ch, 4180c 4 ch
    7" Xenarc VGA touchscreen
    1GHz Via-Nehemiah, 250 GB HDD
    XMPCR w/TOSLink, SB Audigy NX
    Maximum Bitrate yunusyu's Avatar
    May 2004
    Hollywood
    yep...jam it in there !!!!
    DICE Los Angeles
  1. VGA vs RCA & Touchscreen vs other
    By integsrtite in forum LCD/Display
    Last Post: 12-02-2004, 07:07 PM
  2. LCD won't signal MB to power RCA out
    By tropez in forum LCD/Display
    Last Post: 10-23-2003, 04:13 PM
  3. How to convert from Hirose to RCA????
    By AVOGODRO in forum LCD/Display
    Last Post: 11-29-2002, 11:24 PM
  4. Replies: 8
    Last Post: 06-03-2001, 09:16 PM
  5. can I use an amplifier for rca input??
    By sheriff in forum General Hardware Discussion
    Last Post: 03-23-2001, 09:03 AM
