Page 1 of 5 12345 LastLast
Results 1 to 10 of 47
Thread: Turn-on amp POP Stoppers
    Low Bitrate Gene's Avatar
    Jun 2004
    Minnesota
    Question Turn-on amp POP Stoppers
    After doing a on how to eliminate two pops from my speakers when I turn my car on, I came across two products:
    Stinger's http://www.sfxaudio.com/products/dis...p?ProdId=63361
    and David Navone http://www.davidnavone.com/detail.asp?PRODUCT_ID=N-66A
    Do you know any other solutions, what are you using?
    I have one 4ch amp / 4 speakers. Do I need to get only one item or two (one for each RCA cable)?
    Registered User
    Nov 2003
    Long Island NY
    I have the david navone and it works quite well
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    Gene i believe that you need one per device that causes the popping noise.
    Zac
    Zac is offline
    Feb 2004
    VA
    you only need one...it goes in between the remote wire going to your amp
    Variable Bitrate mutilator's Avatar
    Jul 2002
    Staffordshire - united kingdom
    errrm i just use a standard switching relay...
    ignition wire goes through relay to the remote of amp, and is switched by the computers +12v.. that way it dosent power up till after the sound card has started, and powers down when the ignition does.
    tom.
    Jun 2004
    Minnesota
    mutilator,
    I don't know anything about relays, which one would you recomend: SPST or DPDT
    Jul 2002
    Jun 2004
    Minnesota
    Thanks guys
    Jun 2003
    Fairfax, VA
    Gene you would only need a spst for your amp. How it works it, there is a coil inside and when a voltage goes through the coil, it creates an electromagnet which pulls a little switch inside of the relay. You would run the power from the carputer through the coil and the remote line hooks to the internal switch pins.
    May 2003
    Texas
    Some amps have a turn on delay that might be a good solution for some, but my system is personally run with the relay technique. Works great.
  1. PC Motherboard to 1 amp or 2?
    By hanzacra in forum General Hardware Discussion
    Last Post: 11-27-2007, 03:41 AM
  2. car battery
    By Slurpee in forum General Hardware Discussion
    Last Post: 09-08-2007, 06:30 PM
  3. People with NO HeadUnit, Recommand AMP!!
    By camsgs3 in forum Newbie
    Last Post: 07-26-2004, 07:38 PM
  4. Need some help with sending audio to stock amp
    By orangewhip in forum General Hardware Discussion
    Last Post: 09-04-2003, 02:21 PM
  5. amp turn on
    By jasmar in forum General Hardware Discussion
    Last Post: 07-21-2000, 09:51 AM
