yeh its IP-Bus and thatll fit pretty much all newish pioneer head units, check if youve got a blue square connector on the back of yr HU. You will also need to enable AUX for your HU (check the manual)
HTH
Hello, I have a DEH-P4500MP Pioneer HU, The manual shows how to change your source to aux but says nothing about how to hook up an aux input... so, I searched on the forums here and came up with the CD-RB10 adapter as a possible solution. Ebay here I come, well I found this and the ad says its for P-Bus receivers. Question is, is my HU a P-Bus receiver? Is that maybe what the P in the model Number is? and will this adaptor work with my HU?
Edit: <sigh> or is it IP-Bus
HTH
Mods: 18" Boss rims,Twin custom stainless exhaust,cold air induction.
Sound: Pioneer 7400 HU & 6x9's,12" Vibe Sub,600W Kenwood amp.
CarPC: MicroATX, Inverter, WinTV, Lilliput 7", USB GPS
http://www.no1knows.com/galleries/
It does have the blue square, and saw in the manual about setting aux in, thats what got me started on the whole thing,yeh its IP-Bus and thatll fit pretty much all newish pioneer head units, check if youve got a blue square connector on the back of yr HU. You will also need to enable AUX for your HU (check the manual).
Thanks no1knows...next stop ebay![]()
yeh...the rb10 works great. It's not that new either..I've had it for 4 years or so with my DEH-7000r. Only problem now is the the lcd on my faceplate is starting to fade.
