DJKahn85- thanks, thats what I wanted to hear. Good to know you got the Audigy 2 NX sounding good now.
Thanks for the suggestion as well. I did some experimentation today and found that the problem with the break-up at higher volume was indeed the Peripheral Line Out Converter. I think that the cheap pots are to blame - the N-684v on the other hand looks like it probably uses beefy-er pots, hopefully with a good power rating. Hooked up the Bose system to the Clarion and it sounds as good as stock.- but I am worried about the risk of damaging the Bose system so I may get the N-684v. I s/w David Navone via email and that is what he recommended for my setup as well.
On the other hand, I borrowed some coax 5" Rockford Fosgate speakers and hooked them up - they put the Bose to shame. It sounded like the Bose speakers had a towel over them - I never really noticed till now - and now it bugs me. I may stop by the stereo place tomorrow and see what they can do for me, but if it looks like too much $$$, I will just spring for the N-684v (to protect the Bose amps).
The third option would be the pre-amps. In order to get to the pre-amp RCA, I would need to rip the system out for the 3rd time and with my in-dash install it would be a project (but each time I do it I get a little better at it). I also need to search thru the manual to see if the Clarion has the ability to do a balanced output on the pre-amps.
LinkBack URL
About LinkBacks
