Results 1 to 7 of 7
Thread: Can somebody explain use of pressure plate!
    Mar 2004
    I'm building a sub box in trunk for the spare tire hole and saw one install that have a pressure plate and was wondering the meaning and if someone could explain the benefits and howto for that....
    Here what i mean..
    http://www.kalliojarvi.net/kg/golf/golf-10-e.htm
    http://www.kalliojarvi.net/kg/golf/golf-11-e.htm
    I think i install like this if somebody gives me an explanation and reason...
    FLAC djmickyg's Avatar
    Feb 2004
    i think there refering to a cover over the exipment so it can be still used as a boot.
    Mar 2004
    Yes, but i've heard that it brings also some benefits to sound pressure.
    Doesn't anybody know facts?
    This is another setup. Little diffrent but there is same idea.
    Quite bottom on the page.
    http://www.kalliojarvi.net/bx-03-e.htm
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    As a protection & pressure plate there is 12mm thick hardened glass over them.
    I believe by protection he means to keep stuff falling on it, like djmickyg said, so he can still use it as a boot.
    As for the pressure plate, it is used to "seal" the "box" he has made out of the floor of the trunk. It is basically like any other sealed sub box, but he decided to make one side glass.
    Man, when i clicked on this thread, thought we were gonna talk clutches
    Mar 2004
    Quote Originally Posted by binary.h4x
    But in the first pic http://www.kalliojarvi.net/kg/golf/golf-10-e.htm there is 23 litres sealed box under the glass in spare tire hole and yes the glass protects but as pressure plate glass isn't sealed, sound pressure flows from sides inside car.
    That glass can be taken away and play music just like with the glass but what it does??? Is it used as some kind of Transmission Line?
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Man, when i clicked on this thread, thought we were gonna talk clutch bags
    Oh er missus.
    NB sorry couldn't resist.
    -PK
    -PK is offline
    Jul 2004
    Pressure plate
    Hello all.
    System with pressure plate is like closed bandpass box with really small tuned chamber, really short port and very high tuning frequency.
    Normal closed box works as closed rear chamber of the bandpass box. "Pressure plate" is about 60mm away from the box and the space between box & plate works as tuned chamber of the bandpass box. In the pressure plate there is a hole which size is about 25% of the cone area of used subwoofer. The hole works as the port of the bandpass box. Length of the port is same as the thickness of the pressure plate. So the tuning frequency is so high ( much over 100Hz ) that it doesn't mather anything when you are using low lowpass frequency for the subwoofer.
    Benefits of the pressure plate is more controlled and accurate bass response.
    http://www.kalliojarvi.net/autos&sec.htm
    Pasi / http://www.kalliojarvi.net
  1. Strange LED license plate cover
    By MeanGT in forum Off Topic
    Last Post: 04-03-2004, 11:35 PM
  2. Replies: 0
    Last Post: 07-24-2003, 03:42 PM
  3. Tire pressure monitor??
    By claylong in forum General Hardware Discussion
    Last Post: 12-30-2002, 12:32 PM
  4. Replies: 7
    Last Post: 10-13-2002, 09:57 PM
  5. Can Anyone explain the concept of Grounding
    By mprover in forum General Hardware Discussion
    Last Post: 08-21-1999, 11:18 PM
