Most decent quality amplifiers have thermal shutdown circuits in them so frying the amp probably won't happen, however you will have to deal with it shutting down. If you plan on going with the plexiglass (sounds to me like you're going to have the amp completely enclosed) you're definitely going to need fans. 2 fans will probably be enough but I'd put in 4 just to give it the extra air flow, especially if you have to use smaller fans. As far as spacing it off the fender goes 1" should be plenty.
LinkBack URL
About LinkBacks
