Results 1 to 10 of 12
Thread: Sound is *****ed
    Jul 2003
    Sound is *****ed
    Hi,
    First of all I got a lilliput!!!!
    Now I got a problem, I hear my Hard Drive Ticking on my speakers, I bought a new amp. and I still hear it, what can I do about this???
    Possible problems:
    (1) My 3 power cables for the itps are splitted to InCar system and Amp.
    1. Power Switched
    2. Power UnSwitched
    3. Ground
    (2) Everything is to close by each other.
    (3) My Amp. to cheap to weak or *****ed
    Check my own Forum for the complete log about building my own InCar System
    InCar System:
    Epia V10000
    160 GB IDE
    DVD 16X
    USB Bluetooth
    USB WLAN LINKSYS
    NOW WITH SCREEN
    Lilliput 7' TouchScreen
    Maximum Bitrate fluffy2097's Avatar
    Jul 2003
    Fremont, CA
    ground loop.
    A digital mind lost in an analog world.
    Learn to ask smart questions!
    http://www.catb.org/~esr/faqs/smart-questions.html
    My car PC: The Lost Cause!
    Jul 2003
    What is a ground loop???
    InCar System:
    Epia V10000
    160 GB IDE
    DVD 16X
    USB Bluetooth
    USB WLAN LINKSYS
    NOW WITH SCREEN
    Aug 2003
    Moncks Corner, South Carolina
    search buddy, there are countless threads about sound problems and ground loops and how to solve them.
    Jul 2003
    Fremont, CA
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    I would try using a pair of headphones on the computer to decide if it is a problem with the computer or not.
    Variable Bitrate Supermike's Avatar
    May 2004
    AZ
    Is the hard drive and motherboard in a case which is grounded or in some other way attached to the chassis by metal? If not you may want to try and ground the case to the chassis and see if it helps. Also, is the amp grounded to the chassis?
    Also, you should make sure you have all the positive leads to the ITPS and AMP fused at the battery.
    Ground Loops:
    http://216.239.57.104/search?q=cache...s+stereo&hl=en
    Variable Bitrate Fox_Mulder's Avatar
    Melbourne, Australia The Truth Is Out There
    I had this really old Compaq Presario laptop that whenever the hard drive was searching for info you could hear the clicking through the headphones or speakers. This was outside of the car in the house. So I believe it is your soundcard picking up interferrence from the hard disk. Just my 2 cents!
    Fox Mulder
    2001 Toyota Avalon Vxi
    Toshiba TE2000 Laptop 1Ghz BU-353 Black Xenarc 700TSV HD & Analogue TV FM DVD/CDRW Car2PC Adaptor
    2004 Toyota MR2
    Intel Dual Core 2.0Ghz 1Gb DDR2 160GB SATA2 M4ATX Lilliput 7" TS BU353 DiNovo Mini Car2PC ODBII
    Newbie chuckie_mn's Avatar
    Jun 2004
    Minnesota
    Try to plug the computer into wall outlet power, instead of being powered off of car power.
    You will prob find that the hard drive noise in your speakers dissapears.
    - System
    Xenarc 7" Touchscreen, EPIA M 1Ghz , 512 MB, 30 GB, D-Link G wireless, Delorme Earthmate GPS, Gyro Keyboard / Mouse
    - Install Thread
    http://www.mp3car.com/vbulletin/show-off-your-project/28456-1998-audi-a6-near-completion.html
    cheap custom title JC-S60's Avatar
    Mar 2004
    Ghent - Belgium
    Is this an internal soundcard? Then maybe the clicking is due interference IN the computercase (controller/disk/etc...). Maybe try some other sound-source to tour amp and use your computer at the same time (just use the disk a bit). This way you can check if it is coming in on the powerleads or the sound-input...
    Guessing we can do, but the troubleshooting is for you
  1. Sound cards from incarpcs , sacrificing sound quality?
    By skinhead in forum General Hardware Discussion
    Last Post: 09-02-2004, 03:05 AM
  2. Best possible sound quality
    By ST43LTH in forum General Hardware Discussion
    Last Post: 07-06-2004, 09:10 AM
  3. alright, sound distortion from over boosting.
    By ares in forum General Hardware Discussion
    Last Post: 03-14-2004, 01:04 AM
  4. EQ sound question + volume
    By dank_Army in forum General Hardware Discussion
    Last Post: 02-16-2004, 01:09 PM
  5. got sound?
    By masch in forum Newbie
    Last Post: 11-17-2003, 10:01 AM
