Hi, I realized after my last response that you in fact intended to note a diff. bus, but your label threw me off at first.
Note: I only have a few hours worth of experimenting with this so I know my measurements were not finished and I'm probably missing a lot at this point. I can't swear on the data rate until I take some more time with it and measure again (when I figure out why the data capture isn't working everytime).
Here are my ideas based on what you said:
1. Probably not variable data rate
2. I too expect a polling network
3. I wonder if the PIE (or whatever other manufacturer) has a device that can be inspected for more info-didn't PIE or someone else make a Ai-Net compatible adapter?
I had not looked for the connectors yet; that's a good idea. I would like a "break out" cable and much more. I will look into those.
I think I'm going to examine the bus more and come up with another plan.
It kind of ticks me off about the data sheet.
LinkBack URL
About LinkBacks
