Page 4 of 4 FirstFirst 1234
Results 31 to 32 of 32
Thread: Audio Quality
  1. #31
    Jul 2003
    So. Cal.
    I do not think there are factory amps, I think it is all done in the headunit. it's one of those large double din things.
    I'm going to be moving in the next couple of weeks, and I don't have time to mess with the car right now. I'll try the pre-amp and let you guys know how that goes in a month.
  2. #32
    Jun 2004
    Bay Area, California
    best guess is that there is an issue between what you have and what you are trying to play.
    there could be a passive filter filtering out bass to four of the six speakers, and you might not have the subwoofer speakers connected.
    there could be a factory amp that does tee same thing again.
    there could be factory amplifeirs that when you used the amps you have now clip the bejesus out of the amp and reduce audible response in bass frequencies.
    maybe your bass speakers are blown.
    either way, its probbaly either a filter issue, or a damaged equipment issue.
    or a tuning issue. maybe the amp is set to highpass at 250 Hz.
  1. OEM Navigation Connectors
    By Mr Castulucci in forum General Hardware Discussion
    Last Post: 07-20-2010, 06:25 PM
  2. Replies: 19
    Last Post: 12-04-2004, 06:37 PM
  3. Hard audio quality problem: Noise / Ground loop?
    By Burat in forum General Hardware Discussion
    Last Post: 09-09-2004, 07:08 AM
  4. attn fv24 owners audio quality ?
    By etrik in forum General Hardware Discussion
    Last Post: 01-05-2004, 10:38 AM
  5. Complicated Audio Quality Problem
    By StangBoyCIC in forum General Hardware Discussion
    Last Post: 12-17-2003, 04:05 PM
