Results 1 to 10 of 10
Thread: FM CF card
    Low Bitrate Twopoint's Avatar
    Jul 2004
    Kitsap WA USA
    FM CF card
    I have been trying to find something to use as a FM radio for my CarPC. I had most of it planned out and aquired. but I ran acrossed these Compact Flash radios and figured I would give them a try. both said they were support WinXP
    I used a CF\PCMCIA adapter in my laptop
    iBiz - turns out it is an utter waste of time and money, will only work in a PDA and you have to have the PDA in a cradle. sound on it sucks
    Ambicom -loaded easily from CD, came with a patch cord to route the sound out of the CF radio into the input jack. looks like the cord is also used as the antenna (will have to figure out how to connect the external antenna). sound is very clear and no static,
    the software\drivers out of the box, would not let me save the stations.
    reloaded from web site- seems to have solved the problem.
    so anybody used one of these yet? and will MediaCar see them? better then nothing I guess
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    well that was better than my first and most other peoples first post about how they are newbie and hello and please plan my carputer project for me
    MediaCar is kinda on hold.... you may have better luck getting it integrated into frodoplayer. *hint* if you want things integrated into a front end then buy the programmer the hardware
    May 2004
    Norway
    Compact Flash FM Radio?
    Quote Originally Posted by Twopoint
    I have been desperately seeking FM radio card or something for my car PC build - this is the answer to my prayers! Please let me know where to get hold of such a CF card!! Probably others would also like to try them out and my guess is that frodobaggins would like to include support for such cards in his player!? Or perhaps it is as easy as lauching the probably included radio software from Frodo Player?
    Plans + status:
    + Ford Galaxy 2001
    + 7" GAIN (Xenarc) screen
    + 2,5" 40 GB Samsung drive
    + slot-load DVD/CDRW
    + USB WiFi
    - mainboard (Epia SP?)
    - housing (home made?)
    - power supply (Opus 90W/150W)
    - USB GPS + USB card-reader
    May 2004
    Norway
    CF FM radio
    Well, why wait
    I did a and found some interesting links to several CF based FM radios and tests of some of them.
    First, a test of the Ambicom FM radio (XP compatible): http://www.extremereviews.net/data.p...=1&type=review
    A problem with this CF based FM radio seems to be:
    Reception inside the building and in the car was just unacceptable, but that’s why you have radios in your homes and in your car
    Some other similar CF based FM radios (some duplicates, but what the hell ):
    http://radio.about.com/b/a/037889.htm
    http://www.expansys.com/product.asp?code=FM201
    http://www.ibizpda.com/pocketradio.html
    http://www.widget.co.uk/asp/product....rchFor=&PT_ID=
    Both SDIO and CF based Fm radio cards can of cource be put in an PCMCIA adapter if you do not have a CF or SDIO slot (some laptops?).
    My guess is that with either a CF based or SDIO based FM radio, the reception is poor inside a car without having the possibility to connect an external antenna. So then we're back to PCI based TV cards with FM radio since there seems to be no pure USB FM radio on the market (only vapour-ware or TV cards with FM radio )... advantage: you can connect an external antenna and have acceptable radio signal inside the car...? I guess, since I have not yet built my car PC
    Plans + status:
    + Ford Galaxy 2001
    + USB WiFi
    Variable Bitrate HybridMike's Avatar
    Orlando, Florida
    May 2004
    Norway
    Yeah, right, as if that littlu sucker will do it Well, I'm curious to see what your test results show - have just downloaded your alpha 3 release of MMC, so I probably have enough to worry about.
    PS: Why isn't there anyone making a decent car radio in a small box having an external antenna input and USB connection for whatever PC you have? I would love to have one at home as well instead of having to buy a TV card with radio on it...
    Plans + status:
    + Ford Galaxy 2001
    + USB WiFi
    Maximum Bitrate EBFoxbat's Avatar
    Jun 2004
    Massachusetts
    Quote Originally Posted by Smukkasen
    No kidding, how hard can it be? Someone make a production run
    ,./(0)3
    '04 Canyon 4x4 pickup
    [---PC on hold----working on external fiberglass "tool" box---]
    Orlando, Florida
    What, you dont think those CF and SDIO FM radios are little suckers too?? they are just as small, if not smaller, and probably have the same components...
    Im very impressed with it so far, It comes with an external antenna thats like 7ft long, we also are researching a way we can tap into the oem antenna and modify these without losing any reception. we patched the radios output through a RTA (Real Time Analyzer) and found it has an excellent frequency response....
    Supply and Demand there has been no need for a product like that up until recently, manufactuers see it like this, if you are at a desktop then you would want both television and radio....im sure the components to do both are easily found as well, since 99% of the hardware have both Tuners built in to them
    Jul 2004
    Kitsap WA USA
    *sigh*
    I contacted Ambicom to see it there was anyway to connect an external anntena, he suggested I either weld the antenna to the case . . .or buy a dlink usb radio. they have no interest in attempting to support us.
    so use it . . . but don't expect support
    Jan 2003
    Ruston, LA
    Did you tell them to **** OFF ?
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  1. Autorun CF card on insert???
    By Ill1 in forum General MP3Car Discussion
    Last Post: 07-09-2004, 10:19 AM
  2. ebay pci fm tv card
    By streetknight in forum General Hardware Discussion
    Last Post: 04-23-2004, 07:16 PM
  3. Anyone using CF card as boot devices
    By mpattonm in forum Software & Software Development
    Last Post: 04-10-2004, 06:10 AM
  4. FM tuner card, where?
    By ppgt94 in forum General MP3Car Discussion
    Last Post: 04-16-2002, 09:29 AM
  5. FM tuner card with car-style antenna input
    By Chris Snyder in forum General Hardware Discussion
    Last Post: 01-02-2001, 11:01 AM
