Sorry to disappoint you pal, but if you were looking for mid-bass then you bought the wrong brand speakers. Infinity are notoriously weak at midbass and harsh on treble, which I think is exaggerating an already poor quality
sound coming from your PC. Also, you will be chronically underpowering the speakers by using the H/U internal amp, which is rated 4x27W rms (but probably more like 4x15W rms), compared to the their recommended 75W rms.
Unfortunately,the Inifinity BassLink lacks the adjustability, and to some extent the ability; to move its crossover points up to meet and cover the door speakers.
Don't bother messing with the Pioneer
onboard EQ, it's complete garbage. You only have the choice of boosting low/mid/treble which sadly gives similar results to using the Loudness setting (which should also be off).
The solution, either buy a suitable
amplifier for the speakers or just live with the poor quality sound, because no amount of tweaking can restore the midbass which isn't present.
EDIT - damnit my speeling got bad
