USB FM/TV: Hauppauge WinTV/FM USB
Chipset: BT848a (I Think)
Radiator supported: Yes
How its used: Radiator & Plugin
Reception: Pretty Good
Lets see what the brands most people on this board use.
Trying to find a common denominator for generic all purpose software like radiator. Some people can use it, some cant. How do you use yours? From the software in the box? What brand? ANd if you got it to work with radiator, how? Maybe some other people can try your method before they give up.
USB FM/TV: Pixelview PlayTV 2.0 USB Pro
Chipset: VXIS 7012
Radiator supported: No
How its used: Vendor software
New Lilliput EBY701 For Sale http://www.nusantech.com/index.asp?c...at=TOUCHSCREEN
SiRF3 Bluetooth GPS http://www.nusantech.com/index.asp?cat=GPS
Audi S8 supercar
Modded Xbox 400GB HD
Rear 7" screen & navplus
Toyota Hiace Van
Shuttle PIII 866 256Mb 10GB OPUS powered
MediaCar & Mappoint 2004
Custom fit 7" TFT VGA TSK
Those people with BT848/BT878 cards are lucky. Which plugin craigyb? As far as I know, there is only one right?
The standard supplied BT8x8 plugin supplied with radiator.
Using the hacked driver of course.
With the PCI card it worked straight away, with the USB card I had to install the factory USB drivers and then the hacked driver.
Craig
Audi S8 supercar
Toyota Hiace Van
Does anybody here write plugins? On the radiator site it said you need to know Delphi or something to write them.
What kind of technical info of the usb radio do I need to give someone for that person to write a plugin for me?
I cant get it to work!!
OK.... Apparently I keep trying the same driver also but get the same effect (cant load Windrvr)....
I have the (Hauppauge WINTV PVR USB-FM unit) MDL# 43211 REV E123
It works fine with the software that comes on the disk. but radiator says it cant load the driver when I download and install the bt8x8 plugin.
SO lets step back here... maybe your expecting me to have done something else and im assuming I didnt need to. So here are my steps (from a fresh system)...
Steps---->
1) place wintv cdrom in drive.
2) plug in USB cord.
3) direct NEWDEVICE FOUND BOX to the cdrom (drivers load)
4) install application programs (tv & radio) from cdrom (setup program)
5) install *RADIATOR* (do not start it up yet)
6) install *bt8x8 plugin*
7) Start Radiator program (select external driver & bt8x8)
8) Apply........
9) ****get unable to load windrvr
10) **** can not start bt8x8
11) radiator program locks up have to CNTL+ALT+DEL & stop radiator
12) email you for HELP!!!!
so did i miss anysteps...
Chuck
Hauppauge WinTV/FM USB works great for me. No problems
CAR:2001 Ford Crown Victoria
PC: Acer EEE 900HA with Win7 with CF 2.0.
Memory:1G
Drives:160gig
WI-FI:Cingular
GPS:IG2k9
Screen:Xenarc 700TSV
The Florida Meets Thread
well thank you for letting me know it does work...now just got to figure out what everyone else is doing right and im doing wrong
chuck
for starters, i am not using radiator. Using latest progs from hauppauge.
Memory:1G
Drives:160gig
WI-FI:Cingular
GPS:IG2k9
