Results 1 to 10 of 18
Thread: Bass and treble control for Epia M10000?
    Mar 2004
    Vancouver, BC, Canada
    I searched and came up with nothing.
    My problem is that in the windows volume control and in MediaCar the bass and treble controls are disabled. I'm using the EPIA M10000 onboard sound and the VIA audio drivers.
    Does the onboard sound not support controlling the bass and treble?
    Mar 2004
    30 people have read this... one of you must have an EPIA M10000 and know if you can adjust the bass and treble levels...
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    I'm lookin into it.
    Sep 2003
    New Mexico, USA
    Ok, spent 1 1/2 hours on it, can't get it. I've tried different drivers, incl. realtek drivers and Avance ALC drivers. They are all basically the same thing. But anyway, the closest I've got is with the Avance drivers, but I can't get any sound to produce from my computer once these drivers were loaded. Sorry I couldn't help you more. I tested this using my EPIA 800 board, which I think are the same codec wise.
    Mar 2004
    Thanks for trying that out. I would have assumed someone would has said something about this before, since so many audiophiles on this forum must be using this ITX board.
    I guess no one uses onboard sound...
    Variable Bitrate euro320i's Avatar
    Apr 2003
    Near Frankfurt
    Check out the Graphic EQ in WMP9 it's pretty good, and with the SRS sound you can really rock out..
    o/______\o
    (oo_OO_oo)
    []o-----------o[]
    '94 320i
    Jun 2004
    Quote Originally Posted by archimense
    To the best of my knowledge, No.
    I have the same board and tried several methods, including hacking the kernel audio module (when I had linux installed) and from what I discovered/concluded the onboard sound card does not support advanced features such as this.
    Hopefully some one will prove me wrong or a better driver will be written, but alas I forked over some cash and got an Audigy.
    Variable Bitrate Pabs's Avatar
    May 2004
    Somewhere in the UK
    Solution: Plug into amp, use amp controls
    Rs!
    Rs! is offline
    May 2004
    Finally! I found the solution =)
    after hours & hours of searching....
    http://www.viaarena.com/?PageID=328
    Install the vinyl driver and U will get alot of controls for your sound.....
    /Rs!
    Apr 2003
    Near Frankfurt
    Thumbs up
    Quote Originally Posted by Rs!
    /Rs!
    Hey, this kind of persistance is a common trait to many members of this forum.. Congrats!!
    o/______\o
    (oo_OO_oo)
    []o-----------o[]
    '94 320i
  1. EPIA 800: No bass or treble adjustment?
    By rbarr110 in forum General Hardware Discussion
    Last Post: 06-10-2003, 06:08 PM
