Results 1 to 10 of 14
Thread: testing a cap?
    Jun 2004
    testing a cap?
    does anyone know of a way i can test a cap i recently got to see if it is working? i tried and couldn't locate anything
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    charge it, then get like a 12 volt LED, hook it up, and see how long it stays lit. minute or 2 should be good. If that works, charge it again, and hook up a volt meter and make sure it's not putting out a weak voltage. That's the best way I know.
    Maximum Bitrate starfox's Avatar
    May 2002
    Australia
    How big is the cap?
    Jun 2004
    Quote Originally Posted by Tidder
    it wouldn't burn out the led? its like .5 farads i think.
    thanks for the info though
    Newbie Elderm007's Avatar
    Jun 2004
    Michigan
    if you got a good cap it should come with a charging card and what i was told is that after its charged if you put the card back on ( dont charge it ) just see if the green led comes back on if it does your good to go.
    Jun 2004
    Quote Originally Posted by Elderm007
    ah i got it used.. i wonder if i just stuck a volt meter on it after charging it that might work.. if all else fails i can stick a screwdriver across the poles and see what kind of spark i get
    Jun 2004
    Michigan
    nice, I would go with the screwdriver, it will only sting for a sec
    Jun 2004
    Savannah, GA
    A screwdriver?!?! You won't get nearly as accurate a test as your tongue.
    Kefka_Killer.owns(you);
    Sep 2003
    Virginia
    Use a volt/ohm meter. Put it on ohms, the resistance should increase as the cap charges from the meter. Switch to volts, voltage should drop as the cap discharges through the meter.
    Jun 2004
    Quote Originally Posted by mhorton
    thanks, i'll try that.
  1. Problem testing VIA EPIA w/standard atx power supply
    By khufumen in forum Power Supplies
    Last Post: 11-15-2003, 03:22 AM
  2. Anit-Crank-Drop cap solution?
    By All4Norway in forum Power Supplies
    Last Post: 01-07-2003, 09:20 AM
  3. LCD testing Power
    By surfer6262 in forum LCD/Display
    Last Post: 03-14-2002, 12:27 AM
