Well, I think Barometer has a different kind of problem. His
sound card appears to be intialized by
Windows many seconds (30+?) after the CarPC system receives its
power. The DLYON signal is meant to deal with the speaker pop that is caused by
applying power to your CarPC/sound card at the same time as your audio amp/
head unit is powered. There is a 3 second delay on the DLYON line which will not overcome the problem Barometer is running in to. His speaker pop appears to be caused by a
software initialization of his sound card. I'm not sure what a good solution would be for this.
Barometer.....can you get sound out of the sound card BEFORE you hear the pop? 30+ seconds seems like a VERY long initialzation time.
