What do you think is happening inside the amp? In theory a self contained unit should be better than two seperate units but if the amp is using poor DACs itself then performance will suffer. You could also argue the case that the DACs inside the amp are using the same
power supplies as the rest of the amp which could introduce undesirable sonic effects.
In fact, I will go out on a limb here and say a dedicated DAC plus good
amplifier will
sound better than almost all other DAC + AMP combos for a similar amount of money out there.
