Results 1 to 10 of 18
Thread: need a digital input on amp
    Jul 2004
    I need an amp with a digital input since my laptop has a digital output. Anyone know of any? Preferably 5 ch.
    Maximum Bitrate DjBac's Avatar
    Jun 2004
    GREECE/Athens
    Try a DAC or processor!!
    Jul 2004
    The whole purpose is to keep the signal truely digital as long as possible - all the way to the amp. A DAC defeats the purpose. If I have to convert, I would rather go to optical and find an amp with an optical input.
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    Then Google it.
    Aug 1999
    Washington D.C.
    Here you go http://www.cardomain.com/item/PHOR51MT
    I ordered one this morning to test out. It looks like it should be ideal for people considering doing away with a head unit yet still having good control over their speakers. It has on screen programming, optical in, and coaxial in.
    Jan 2004
    California
    That looks pretty nice. Not too bad of a price either. I wish it had a little bit more power at least on the subwoofer channel.
    What do you think is happening inside the amp? In theory a self contained unit should be better than two seperate units but if the amp is using poor DACs itself then performance will suffer. You could also argue the case that the DACs inside the amp are using the same power supplies as the rest of the amp which could introduce undesirable sonic effects.
    In fact, I will go out on a limb here and say a dedicated DAC plus good amplifier will sound better than almost all other DAC + AMP combos for a similar amount of money out there.
    Jul 2004
    I also think a good DAC and a good amp will sound better. You can send the signal with a fiber optic or high end digital cable and then use high end RCA to send to the amp (as close as possible to the DAC).
    Altough Phoenix Gold makes really good amps, they aren't as good since their head engineer is now in a new co. called Concept.
    Plus when having a separate DAC, you can then send your signals to many amps, controlling perfectly the power you want for your components.
    Etienne
    Jun 2004
    GREECE/Athens
    In my opinion and experience Alpine's PXA-H900 is one of the best processors that can do the job!!! It also has 11-ch outputs!!!:P:P
    Jul 2004
    Quote Originally Posted by DjBac
    your'e talking about the top of the line
    if you have th emoney, that's the best you can get!!!
    Etienne
  1. PC Motherboard to 1 amp or 2?
    By hanzacra in forum General Hardware Discussion
    Last Post: 11-27-2007, 03:41 AM
  2. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 12:54 PM
  3. Digital Amp
    By turbopropper in forum Car Audio
    Last Post: 07-07-2004, 03:34 AM
  4. DSP/EQ with a digital input (repost)
    By belezeebub in forum General Hardware Discussion
    Last Post: 03-24-2004, 07:20 PM
  5. amp with digital input?
    By etrik in forum General Hardware Discussion
    Last Post: 05-08-2002, 07:15 AM
