Personally i like the dlink dsb-r100, others like the radio xtreme. But i think whatever you get, don't count on perfect reception.
I'm interested in using an FM modulator to get some from my laptop, Any reccomendations on products?
thanks,
c4shm0ney
I think he is referring to a fm transmitter/modulator; the dsbr100 is a fm tuner...Modulators/transmitters are known to be subpar to aux in jacks on headunits or direct connections to amps, but you should be able to go to any car stereo store and get an inline modulator, or you can go to walmart and buy an fm transmitter (does not directly connect to antenna line); both will do the job, and a modulator will work better, but neither will work as well as the direct connections to the hu or amp...
http://www.myfmstation.com/html/linex_usb.html
Linex USB FM transmitter.
It shows up as 'USB Speakers' on a Windows system. (Don't have to deal with aux-out/line-out, etc.) It's powered off USB. Boss has one and it works great.
I know these are known for their horrible sound quality, and all but can anyone attest to the quality of this device? Has anyone heard it, and could compare it against other modulators?Originally Posted by Kermee
2000 Subaru OBS
Dell P3 @ 900 Mhz
7" Lilliput TS w/DigitalWW in-dash mount
80GB External HD
I am Zero Bitrate....
Thanks guys, I ended up picking up a $19 sf100 "SoundFeeder" from BestBuy and I'm really unhappy with it. The D-LINK DSB-R100 looks promising.
I have a Clarion FM200 Fm modulator if you are interested!
Send me a PM
Laz
I one try to use FM Modulator for aux input to the Apline HU, but the sound quality isn't compare to the tape adapter. So I return it. If your HU can do tape, use tape adapter instead of FM Modulator. Don't get FM transmitter
In my opinion.
True aux input (HU capable) 100%
Tape adapter 80~90%
FM Modulator 65~85%
FM Transmitter 0~75%
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
i'm loharisan from malaysia...
i'm new in car computing and i'm glad to share any information with all of you about car electronic system esp. in computer installment and modification inside the car.. and my first question is how many battery did people usually install inside the car to make sure the computer system really works?? and for my peugeot 406 can it carry all this voltage and didn't effect on the batteries like any american and japanese cars?? for your info mtv pimp my ride inspired me to follow all the modi just like all of you being discussing.. that's all..
thanks and please make some respond to an amateur like me..
