Can this DAC be used?
I was wondering if I could use this DAC to send a good clean signal to my Xtant 3-channel amp from my EPIA Via M10k motherboard? Thanks for any help! http://www.nakamichiusa.com/auto/musicbank/dac_41.htm
~Adam
It seems this is like a "linear" converter, it takes the signal from one digital line to output on one analog line.. twice like that.
On a DAC for the M10k you need a converter that takes one digital input that has the 5.1 signals for all the analog outputs.
Maybe someone can confirm?
Etienne
Can someone please confirm?
You said 3 channel amp. Is that fronts and subwoofer or what?
That DAC seems overkill... I don't think you need 2 in and 2 out. What are you trying to accomplish?
Yes its fronts and sub...., im not worried about overkill, if It will work thetn its what I will use, I can get one quite cheap, I am looking into sending then absolutely best sound signal from my PC to my amp, and I was told that the SPDIF on my Via M10k was the best way to do this, so I guess the question is, can I hook this DAC to my SPDIF output on my Via M10k Mobo and then hook this Nakamichi DAC to my amp? Thanks for te help!
~Adam
If you are looking at the one on Ebay that ends in 30 min, look at the DAC-101. It is a better unit - IMHO. There is one with a "Buy It Now" of $80 plus shipping ($15). I would get it, but have a different priority right now.
Is that a "yes" it will work answer?
I don't see any reason why it wouldn't work.
If it didn't for some crazy reason, you could easily flip it back around on Ebay.
6 min left for you to decide on this one.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
