yeh, facing backwards leads to better bass, unexplained but proven, ill try find the site that tested it.
Hi all. I just picked up a new subwoofer over the weekend and dropped it into my trunk. Its a pain in the *** to move it around (read: heavy) but a friend of mine said it would sound better if it turned it 180 degrees so that it was firing backward. This makes no sense to me since I sit at the front of the car. If anyone has some more input on whether the sub should face forward or backward, I'd like to hear it...
2 Kicker CVR 12", Audiobahn A8002T (400 watts per channel).
Incidently, it does sound good as it is... I'm just not sure it will be all that better the other way around.
Mods: 18" Boss rims,Twin custom stainless exhaust,cold air induction.
Sound: Pioneer 7400 HU & 6x9's,12" Vibe Sub,600W Kenwood amp.
CarPC: MicroATX, Inverter, WinTV, Lilliput 7", USB GPS
http://www.no1knows.com/galleries/
its becuase if its facing da back of the trunk theres more space for the air to move and creates more vibration witch its perty much wat bass is where as if it faces your seats then the air hits the back of the seats and bounces back or around and makes the subs work more or is just absobered by the seat well thats wat i think at least i know it dose sound better facing back tho becuase i have tested it in many differnt cars
I thought turning the box around equals 'boomier' or 'sloppier' bass.
This usually is good for rap/hiphop.
Facing forward is more oriented to rock/pop? ie 'punchy' bass.
I think this is what I was always told too, but I think what type of box you're using makes a big difference as well.Originally Posted by ZanGManN
Hmmm... interesting input. I guess I'll have to turn it round and give it a shot. I listen to techno music mostly so that fits in with the 'boomy.' The biggest problem at the moment is that the whole fugin tunk rattles way more than I would think it should for the ammount of bass being generated.
I rememeber reading somewhere that subs sounded better if they face upwards towards the car's cabin?
- 3+ years & still no carputer!
- Done collecting parts
- Currently planning setup
most newer subs are designed well so that it won't hurt them to be facedup, but a lot of older and lower quality subs will start to get a sagging basket from sitting firing up all the time.
As for the direction, bass is non-directional anyway so it doesn't really matter, but everyone faces it firing backwards... just the way things are done. jay187's idea that it has more air to move around that way sounds like a good explanation, I find that the bass sounds best when you can't tell its coming from the trunk, ie you just hear and feel it all around you, and facing it backwards will give you that.
hope that helps. all you can do tho is turn it around and see how you like it each way.
I heard it sounds better when it's in my car.
So if you could go ahead and send them UPS and pm me the tracking #![]()
Here's some science behind which direction works best: http://www.installer.com/tech/aiming.html
Bass is omnidirectional, but in the confines of a car, you get the added effect of cancellation to worry about.
