Results 1 to 6 of 6
Thread: batteries
    Jun 2004
    batteries
    i am new to the whole driving thing im planning my carputer atm and my ice install but i was wondering how u power it do u run it off of ur ca battery or get another battery if so how do u keep it charged?????????
    May 2003
    UK
    can be done either way, if you use a seperate battery you use a battery isolator to allow it to be charged by the main alternator - but of course you have a lot of extra weight to slow your car down - I can run PC + screen + 500W of audio for about 5 hours no trouble of the main batt...
    James
    www.digital-car.co.uk - The UK CarPC Forum
    Top Ramen lgbr's Avatar
    Feb 2004
    Spokane, WA, US
    What kind of car do you drive? I almost wasted the alternator in my civic from having a battery isolator. I have a 250 Watt power supply (that's a lot for a carputer) and I run my carputer off one optima yellow top battery just fine.
    Powering the computer is pretty simple, you replace the power supply that uses house power in your computer with one that uses a car's power. Run a wire from the (+) battery terminal to the power supply, ground it, and you're set.
    Audio Rockford Fosgate: 900 Watt 4-channel amp, 501bd Mono amp
    Computer AMD 2400+ XP, 1 GB DDR RAM, Orbit Micro 250W DC-DC PSU
    Head units are for cheaters!
    sure some girls fake orgasms.....but it's guys like me who fake the whole relationship
    Low Bitrate Pogi's Avatar
    Sep 2003
    West Palm Beach, Florida, United States
    yah, I was bout to say. Get an Optima call it a day.
    Variable Bitrate danon's Avatar
    Oct 2003
    Queensland, Australia
    Quote Originally Posted by Bennai
    please check:
    need help w/ extra battery
    i'm in post #5.
    also:
    What Gauge wires do I use?
    mine is in post #15-#16.
    ...tons of help from my actual experience as well as others.
    danon
    [....99.9%]
    [HW] 566eMHz/128mb/6gb, FlyVideo3k, RandMgps, M1-ATX, 7" Lilliput, VGA2AVadptrFor2ndVideo, 4CH/100rms, 10"Sub, 40AhDeepCycleTank
    [....99.8%]
    [SW] XP/MMC/FP:D3,FlyTV/AxifeFM,CarMM?
    [Working on] puttingBackEvrythg.
    Check Here. I have one of these in my WJ (Grand Cherokee) and it is working wonderfully. You are able to switch from using just the main battery only with the aux disconnected, use both batteries in parrellell which also allows the charging of the aux bat(with key in on position), and there is an emergency position to allow you to use both bat in parellell with key off. This setup allows me to run the carputer off the aux bat while it is isolated from the cars main electrical system and then I can charge in whenever I want with a flip of a switch.
  1. Two batteries in my ride
    By SAScooby in forum Power Supplies
    Last Post: 10-28-2009, 02:23 AM
  2. Optima batteries
    By turbochris in forum Power Supplies
    Last Post: 05-06-2004, 10:54 PM
  3. Questions on batteries
    By Sir_Pyro in forum Power Supplies
    Last Post: 03-25-2003, 09:34 AM
  4. running off car batteries
    By Ice9 in forum General Hardware Discussion
    Last Post: 02-27-2003, 10:16 PM
  5. Powering LCD panel with batteries
    By paulw in forum General Hardware Discussion
    Last Post: 11-01-1999, 02:37 PM
