Page 1 of 5 12345 LastLast
Results 1 to 10 of 46
Thread: Subs for carputer!
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    Subs for carputer!
    Hey guys I'm looking for subs to use with my install. First let me tell you guys that I don't know much about the audio part of the install. I know the basics of car audio, not too much.
    That being said I looking for two 10's or 12's for my car. They don't need to be extremly lound but they do need to have good sound quality. I'm going to be keeping my stock speaker for now, I'm just looking for the subs and amps to go with them. I will not be using my head unit just the amps for all the speakers. I don't want to spend a lot of money on them, my budget is something around 350 for the subs and amps. Any suggestion are welcome.
    I was considering the Rockford Punch series 2 or the Adire Shivas. Let me know what you think of these. Also if you could recommend amps to go with the subs it would be great.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
    Maximum Bitrate brrman's Avatar
    Aug 2003
    Indianapolis, IN USA
    350 for 2 subs and an amp??? not much to work with there, man.
    You could get 10" Infinity Perfect Subs for around $100 a piece. Thats what I use in my car and they really punch hard. I am not sure what to tell you about an amp. Been a while since I looked at amps.
    Car: 2000 Audi A4 Avant 1.8t
    Carputer 2.0: removed. Back to stock.
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    Sheesh I have a 10" Pioneer in my car and thats plenty, if you keep an eye on Circut City and Best Buy, sometimes they have open item boxes and subs together I saw a dual 12" sub box with 2 kicker subs for $100, which from what i've seen is great deal considering most subs are at least $50 to $60 a piece and thats buying a non name brand sub.
    Dec 2003
    New York
    My budget is flexible, but I don't want to spend a lot of money of the subs and amps, so something a little higher than 350 would be ok.
    Installed
    Jun 2004
    Upstate New York
    Quote Originally Posted by brrman
    He's right, you might consider bumping up your budget a bit. This amp is a mono amplifier and stable to 2 ohms which means you could wire 2 subs in parallel to it and push 420W (Max I think). Price on that amp is $189 and it's about as low in quality as I'd ever buy. However since it's a sub amp it doesn't need to be super clean and should work fine for the designed purpose. If you went with a pair of MTX 10" subs from the same site you'd come in under you $350 budget. Quality won't be the same as with higher end products, but will probably fit into your system quite nicely since you're keeping the factory speakers. Been a while since I listened to any of Rockford's stuff, but I didn't care for them then and have stayed away from them because of it (bare in mind it's a personal preference).
    May 2004
    South Florida
    I am running with two Rockford Fosgates (I paid 45 each from www.ubid.com) and a JBL mono amp which I got for 200 off ebay. I just finished building up my car and will be posting it tonight to tomorrow. Remember the enclosure is the key to good bass. Understand the different variations of enclosures and find the speakers that will work best with that enclosure.
    The best sub I have worked with (especially if space is an issue) is the Kicker Solo Baric. Extreme amount of Bass very little volume required for the box. Look around I have found this complete with enclosure for under 200.
    Dec 2003
    New York
    I'm not worried too much about the space being taken up in my trunk, so the size of the enclosure doesn't matter. I'm going to be building a custom enclosure, probably ported. That is why I'm looking for the subs first so then I can make the enclouse according their needs.
    Installed
    Variable Bitrate Pabs's Avatar
    May 2004
    Somewhere in the UK
    ebay...
    loads on there, find some u want then buy second hand! not really much that can be wrong with a speaker. it works or it dont!
    lol
    Maximum Bitrate falconey's Avatar
    Feb 2004
    Atlanta
    Get you some some jl's you'll never turn back. You could even go with a one 12w6 with a nice 600watt rms amp and I'd guarantee you'd love the sound.
    Newbie xcdhridr's Avatar
    May 2004
    you don't need 2 subs. one is plenty. just figure out what enclosure you want. I prefer sealed cause of the tighter bass (but my current setup is vented). I'm running a cheap ($10 after rebate) infinity 1030w right now with an old jbl 600.1 amp. this setup if fine for me. I was looking to keep the size/weight to minimum. I'm going to be swapping the jbl with an audiobahn 8001 very soon for matching amp (got 6004 in for 4 channel now).
    Seriously, unless your screaming for outside attention, 1 10inch (or 12 if you really want) is fine for really good sound quality. Anything over 400watts would be good. no need to go over 800
  1. ebay: 2 12" PPI Pro Subs w/ Enclosure
    By migel628 in forum Classified Archive
    Last Post: 08-09-2004, 04:10 PM
  2. MOBO severly vibrating from subs...
    By syclone477 in forum General MP3Car Discussion
    Last Post: 05-04-2004, 11:46 AM
  3. F/S: Amp & Subs
    By 89Excess in forum Car Audio
    Last Post: 04-17-2004, 11:50 PM
  4. FS/T 2: Car Audio Equipment (Amps Subs HU's)
    By Skippman in forum Classified Archive
    Last Post: 06-16-2003, 08:12 AM
  5. 250 watt subs affecting harddrive/other computer components?
    By DerekG in forum General Hardware Discussion
    Last Post: 05-13-2001, 09:22 PM
