Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: CarPC directly into Monsoon Amp, do I really need the Head Unit?
    May 2004
    Question CarPC directly into Monsoon Amp, do I really need the Head Unit?
    For space reasons I'm removing the stock monsoon head unit on my '01 Jetta and replacing it with a 7" touch panel. I've constructed a plexiglas case to fit into the CD changer slot in the back and I'm hoping to use a RCA to monsoon harness on the CD changer input in the same slot.
    Like I said before the HU will be gone leaving volume control to Windows I hope. Question is will this work? Can windows just pass a signal via RCA/monsoon to the amp then to the speakers?
    Jun 2004
    Seattle
    You bet.. similar to mine, and it sounds 10X better. You might need a line driver however, cause you are going to the CD changer first. I had mine running to the amp first. (I don't have a CD changer)
    Aug 1999
    Washington D.C.
    Does your Monsoon amp have RCA inputs? Mine doesn’t, it just has high level (speaker level) inputs. I've read on the Volkswagen forums that the Monsoon amp isn't like a traditional amp. The head unit does most of the amplification and the amp functions more as a cross cover to drive the separate tweeters and woofers in the all the doors. I’m not totally sure, but I am going HU less too. I just have a smaller amp that leads into the Monsoon amp.
    FLAC ppgt94's Avatar
    May 2001
    USA
    I have a '02 Jetta. I removed the moonsoon black "box". I then got the pin-out for the connector that plugged into the box and soldered my wires onto it to go to a amp.
    May 2004
    Quote Originally Posted by Zip-Lock
    So how exactly do I get purely software control of volume, I want no dials switches or sliders.
    May 2001
    USA
    Quote Originally Posted by ericthebikeman
    Run the audio output of your comp's sound card into a amp.
    May 2004
    Quote Originally Posted by ppgt94
    So computer > amp > monsoon "amp" or
    computer > monsoon amp
    May 2001
    USA
    I removed the monsoon "amp". Then I soldered speaker wires to the speaker leads. So it goes Computer > Amp > Speakers. I'll take a picture tomorrow.
    Oct 2003
    I also removed the Monsoon "Amp" and put in a 4.1 Alpine.
    The front and back speakers have different power requirements (8 Vs 4 Ohms). I dealt with this issue by reducing the level to the front speakers. Also, you need crossovers for the tweeters. I used some spare Memphis crossovers.
    This set up sounds very, very good. To the point that I had to start using lossless compression for my music.
    cheers,
    Jul 2004
    Minneapolis
    The Monsoon amp in that vehicle is (I believe - about 89% sure) a current sensing amp. I'm not guaranteeing anything but you could definitely try running your lineouts of a soundcard right into the amp and see what happens. If you get a wiring harness from a local car stereo shop it would make your life much easier. You could do 1/8" out to RCA from the sound card but cut the ends of the RCA's off. Then just hardwire right into the speaker wires where the radio was. I can't say for sure this will work but it definitely could. My only concern is I don't know if there will enough output on the sound card to be worth it. Best luck!
  1. no head unit amp
    By turbochris in forum Car Audio
    Last Post: 07-03-2004, 06:30 AM
  2. Review: Kenwood KDC-W6527 Head Unit
    By chewiee in forum The Review Palace
    Last Post: 06-22-2004, 03:14 PM
  3. Head Unit Vs. amp
    By cadence117 in forum Car Audio
    Last Post: 04-26-2004, 11:59 AM
  4. I eliminated my head unit, how about a 4-channel amp and preamp/equalizer?
    By guitar333 in forum General Hardware Discussion
    Last Post: 09-29-2003, 12:06 AM
  5. Easy head unit question, and PC to amp question.
    By dudah85 in forum General Hardware Discussion
    Last Post: 09-09-2001, 04:57 PM
