Results 1 to 2 of 2
Thread: Noise in audio
    Low Bitrate cavramair's Avatar
    Aug 2003
    Noise in audio
    I hooked my pc to the auxilary input of my Blaupunkt San Jose. The sound is good, I got it hooked to the right pins, but there is some alternator whine. The stereo sounded great before I hooked the pc up. Should I install a line level input filter on the output line of the pc? Would this remedy the situation?
    -Drew Taylor
    2000 Grand Am GT PC
    Raw Wave Defiler's Avatar
    Jan 2002
    Temple Terrace, Fl.
    Make sure all your grounds are good and properly done. Try grounding the case of the carputer and PSU. Are you using an inverter or a DC\DC PSU? If using an inverter try using a single outlet noise\line filter.
    Aura MR62 (F and R)
    My Current MP3s
  1. OEM Navigation Connectors
    By Mr Castulucci in forum General Hardware Discussion
    Last Post: 07-20-2010, 06:25 PM
  2. Noise on audio from laptop
    By pip in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 11-24-2006, 08:09 PM
  3. noise in audio
    By Harvester in forum General Hardware Discussion
    Last Post: 10-03-2005, 08:40 PM
  4. Audio noise, only with Lilli LCD on.
    By muldrick in forum LCD/Display
    Last Post: 08-11-2004, 07:45 AM
  5. How to eliminate noise in audio
    By felix99 in forum General Hardware Discussion
    Last Post: 09-20-2002, 12:31 PM
