Results 1 to 4 of 4
Thread: where to attach
    Aug 2004
    where to attach
    Ok presume this
    Car pc -> ampl ->? car speakers
    ok followed me trough this steps? No the question is to go from the ampl to the original speakers trough the original hu plugs/sockets (I mean the ones you use to connect your hu with your car) The question is where do I put the wires for front L/R and rear L/R? So i have this sockets with sixteen or more holes so where are the ones from the speakers??
    Car is a Opel Corsa 1.7 cdti hu siemens cdr 2005
    also view
    On pic nr 4 you can see the blue sockets so there I want to connect but don't know wich holes to use
    If anyone can help me please thx
    Constant Bitrate CHUPACABRA's Avatar
    Mar 2004
    G'ville S.C.
    Well for one thing you should be able to get a factory harness plugin to use aftermarket HU. that will give you the pin out of the wires. second for best sound go with a soundblaster live or above sound card with a 4 chanel amp.mp3s will still use the 4 speaker setup as well as dvds. As for wireing the speakers just wire some 18 gauge wire to the speakers cause the factory one are probaly only 22gauge.
    Maximum Bitrate fantomas's Avatar
    Nov 2003
    my advice would be to buy a wiring harness. most wiring harnesses ive seen say what the function of the wire is rihg ton the wire itself. not every manufacturer makes their wires the same color so i cant tell you exactly which ones are which. you could also test out each wire set. for example, plug in the gray and gray/black wires nd see which speaker that comes out.
    rebuilding carpc... kinda..
    Aug 2004
    thx maybe I'll just have to search search search till I drop
  1. How do you attach pictures?
    By mportobello in forum Off Topic
    Last Post: 05-31-2004, 04:53 AM
  2. Matsu****a SR-8185-C (Apple) DVD and Allmac adapter wiring?
    By millec in forum General Hardware Discussion
    Last Post: 05-26-2004, 05:02 PM
  3. How do I attach (2) ide cables together?
    By Scafremon in forum General Hardware Discussion
    Last Post: 01-03-2004, 08:21 PM
  4. How do I attach two IDE cables together?
    By DouggyDouggy in forum General Hardware Discussion
    Last Post: 07-10-2003, 04:34 PM
  5. For Moon, Aaron, Ziplock.
    By Mastero in forum Mp3car Forum Suggestions/Comments
    Last Post: 04-06-2002, 02:58 PM
