Results 11 to 20 of 24
Thread: Relocate 99 Accord Head Unit
  1. #11
    Oct 2003
    Idaho
    Wink
    Ok........got it relocated to bottom tray area. Needs lots of work though. But atleast its a start on the right path.
    Check it out
    http://myweb.cableone.net/nicknack/
  2. #12
    Aug 2004
    what you shouldve done is keep your stock radio where it is and put the screen in the cubby hole near the shifter like this dude:
  3. #13
    Variable Bitrate RogerWilco's Avatar
    Aug 2004
    thats what im doing in my ford explorer, just about the exact thing, just putting my lilliput under the stock HU, anyways it might not be neccesary to buy that converter cable. I have a Blaunpunkt san jose MP41, and they make a aux converter cables just like that one that converts it into a single RCA input. The negative thing about that, is if you get a computer with 4 or 5.1 surrond, it will do no good. So i simply cut the connector off and solderd multiple RCA inputs on, not 100% sure thats the exact same deal you have, but just givin you a heads up. Hope It helps
    Btw nice job relocating the HU !
  4. #14
    Aug 2004
    du3ce, i am doing the exact same thing. i am getting the faceplate made custom for me with extra slots for the controls for the monitor, and for my inverter, so i can watch the voltage/watts, etc. what is your enclosure made from, and how did you secure it?
  5. #15
    Aug 2004
    hey djpm05 where you refering to placing your inverter in your dash? or running something else to monitor the volts and watts? if you were considering placing your inverter in your dash, i highly advise against it. The inverter will most likely overheat, and it will be real noisy in an enclosure like that and near to you. And in the event you were going to use something analog to monitor the volts and watts, what is it?
    Thanks!
  6. #16
    Aug 2004
    Quote Originally Posted by djpm05
    thats not my ride, i gotthe pic from a guy that post on an accord forum (www.v6performance.net) his name is wuzcrackin
  7. #17
    Dec 2003
    So how many people here have a 6th gen Accord?
    www.99Accord.com
  8. #18
    Maximum Bitrate yunusyu's Avatar
    May 2004
    Hollywood
    I do
    DICE Los Angeles
  9. #19
    Jun 2000
    NYC
    I got one...see signature.
    I'm also a recent member of v6p.net even though I drive a 4-banger.
  10. #20
    Dec 2003
    Yeah, V6Performance.net is a great site! I have been a member for over 2 years. (Back when it was AccordV6.com)
    www.99Accord.com
  1. Can a car-computer replace a stereo head unit?
    By CA 3000GT in forum General Hardware Discussion
    Last Post: 11-13-2006, 09:24 PM
  2. Stock head unit (ford taurus)
    By frostband in forum Car Audio
    Last Post: 12-26-2004, 12:14 AM
  3. Review: Kenwood KDC-W6527 Head Unit
    By chewiee in forum The Review Palace
    Last Post: 06-22-2004, 02:14 PM
  4. Slot load dvd in a head unit
    By mp3truckstereo in forum General Hardware Discussion
    Last Post: 09-01-2002, 10:17 PM
  5. car head unit
    By BoneMan in forum General Hardware Discussion
    Last Post: 07-29-1999, 09:30 PM
