Results 11 to 20 of 22
Thread: Higher output alternators
  1. #11
    Newbie specsix's Avatar
    Aug 2002
    Sedro Woolley, WA
    Pheonix Gold or Stinger
    I have a pheonix gold ...dont remember the model number because I installed it about 7 years ago, but it puts out 175 amps on a Dodge Ram 50.
    About the horse power statement. Technically yes, your engine needs to work harder, but you wont notice it. You cant even feel horse power to begin with and 2nd it will not affect your gas miliage. I have been using this alternator for 7 years and my gas miliage is the same.
    I use a battery isolater to 2 red top optimas and never have had any issues running my 375 amp stereo (300 for bass and 75 for highs). Never cuts off and never goes below 12 volts.
    I would look into a Stinger dealer. They usually will set you up with the kit and instructions. Its not cheap though.
    Don't go dual alternator. There is nothing wrong with it, but you can get alternators even higher than 200 if you have the money.
  2. #12
    Maximum Bitrate falconey's Avatar
    Feb 2004
    Atlanta
    Ohio generaters(that's the name or something similar) has a great rep in car audio.
    Also iraggi alternators.
  3. #13
    Variable Bitrate RogerWilco's Avatar
    Aug 2004
    Well conveintly the post / link at the begining of the thread has a 200 amp for my vehicle for a mere 225$ is this as good as it seems? previous alts i've seen have been much more expensive its for a 98 ford explorer xlt v6 SOHC,
  4. #14
    Mar 2004
    New Jersey
    Frodo, if you want true isolation i would go with 2 alternators.. i ran a pretty hefty system with a dedicated 130 amp alternator to the back battery and i never had any problems.. i lost mabye .5-1MPG and no noticable HP..
    i picked it up for 100 bucks and never worried about it until i sold the car.. i put about 120k miles on that set up.
    -Jack
    2006 Chrysler 300C AWD
    Samsung Galaxy Tab In dash
  5. #15
    Aug 2004
    how much do you have to custom you goodies to get dual alternators to fit?
  6. #16
    Jun 2004
    Upstate New York
    I don't think they're still making them. Checked their site and didn't see anything listed. We used to carry them when I was doing installs though and never had any problems with them, they always worked great. The Ford one may be the way to go though since you'll have less trouble installing it than with an aftermarket one I would think.
  7. #17
    Jan 2003
    Ruston, LA
    Quote Originally Posted by RogerWilco
    Comes highly recommended on rps forums.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  8. #18
    Jan 2003
    Ruston, LA
    Quote Originally Posted by Kamakazie2
    http://www.alternatorparts.com/Doubl...fier_cs144.htm
    This is where i got my 250 amp alternator for my stereo system... hmmm power...
    250 Amp ! ?
    Damn
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  9. #19
    Jun 2004
    Bay Area, California
    check to see what kind of output it makes at idle, and what output it has at high rpms. realize that lower outputs at idle can lead to dimming at stoplights, or poor performance at competition.
    make sure the alternator will perform how you want. If you only want 130 amp output, you shouldnt have to buy a 250 amp alternator just to get that output at 800 rpm....
  10. #20
    Aug 2004
    so im taking it that roughly ~ 838 rpms is average at idle?
    Is there a indivdual constant for an alternator in amps per rpm or does it exponetaily increase?
  1. Is all coax/optical spdif output created equal?
    By Choser in forum General Hardware Discussion
    Last Post: 12-19-2004, 03:48 PM
  2. Replies: 13
    Last Post: 07-26-2004, 12:25 AM
  3. Car Alarm Aux output and Shutdown controller
    By MatrixPC in forum Power Supplies
    Last Post: 05-09-2004, 08:36 PM
  4. tank circuit - what output do I need?
    By maxcosity in forum Power Supplies
    Last Post: 06-03-2003, 05:00 PM
  5. No lcd output
    By JettaMP3 in forum General Hardware Discussion
    Last Post: 03-12-2001, 03:27 PM
