Results 1 to 5 of 5
Thread: Digital Amps eliminate noise?
    lbk
    lbk is offline
    Feb 2003
    Chicago
    Since the data is being sent to the amp digitally does this completely eliminate feedback from the alternator?
    I know on the EPIA boards you can output digital audio through the RCA jack, and was wondering if there are any feedback advantages not just sound quality.
    Maximum Bitrate falconey's Avatar
    Feb 2004
    Atlanta
    No proper installation does though.
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    Unless you're doing it optically you're still creating an electical connection between the PC and amp!
    I've got mine hooked up via analogue, and there's no noise at all, because all my audio equipment is grounded properly, and to the same point on the chassis
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
    lbk
    lbk is offline
    Feb 2003
    Chicago
    Ok then I'll do proper grounding and forget about the $500 + amps.
    Maximum Bitrate DjBac's Avatar
    Jun 2004
    GREECE/Athens
    it may produce noise if the source of it is after the amp!!!
  1. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 12:54 PM
  2. Replies: 86
    Last Post: 04-04-2005, 04:57 PM
  3. Got some humming/buzzing noise out of stock system
    By Bxscig in forum General Hardware Discussion
    Last Post: 07-31-2004, 03:39 PM
  4. Digital audio source switching by PC - possible?
    By slushieken in forum General Hardware Discussion
    Last Post: 04-14-2004, 11:41 AM
  5. How to eliminate noise in audio
    By felix99 in forum General Hardware Discussion
    Last Post: 09-20-2002, 12:31 PM
