Results 1 to 6 of 6
Thread: volume control
    Constant Bitrate JaxPt's Avatar
    Jan 2004
    volume control
    I just finished my system and for the most part everything works great. heres the basic layout, the puter/PSu are located in the subfloor/amprack in the rear , EQ is loacated in the glovebox.
    DEI 600/5 amp 4 gauge ground to the chassis and 4 gauge power from the battery along the drivers side to the distro block, 4gauge from the distro to the amp and inverter using the other output from the distro block. the inverter is grounded to the same point as the amp on a seperate cable
    PC: samsung board from a gatewayy 500 pc. 500 mhz, 256mb pc133
    on board sound to a y adapter to rca input of a 5 channel kenwood eq with sub xover. 5 channels from the eq to the amp running along the pax side of the
    lilliput touchscreen, currently not touchscreen due to cable problem, therefore the software is controlled by an IR keyboard with built in mouse
    the keyboard has built in vol/track controls
    software is mediaengines latest ver
    I have a few problems however.
    1: volume, when i turn on my system i can hear everything through the amp, hard drive spinning up etc and when i run winamp, mediaengine, mediaplayer the volume is really high. I cut the main windows vol to almost zero and still doesnt help, in media engine i can have either 0% vol or 2% if i put it at 2% its LOUD!!! only soultion i can think of is cutting the gains on the amp way back, hard to beleive that switching from a reg headunit to a pc soundcard that the gain would be affected so much...any other suggestions before i cut the top end of my system?
    2: noise, humming and buzz through the speakers. its tolerable when something is playing but otherwise its drivin me f'n nuts. the sound system and inverter are grounded very well. i know my car audio installations. the rcas are all shielded and away from the electrical as far as i know, power is down the left side of the car and sound is down the right side. possibly EMI from the mobo and PSU near the amp? any suggestions of how to fix it?
    also i need to fix my POS vga/usb cable for my lilli touchscreen. I read a thread here that said you could swap it to a DB9 vga extension, can i just hack one side of the DB and the cannon plug off the lilli and solder the wires and can someone give me the proper wire color connections to do this? I'm kinda confused on this one because of the vga/usb intergration in that cable
    thanks
    2003 PT Cruiser
    Sony, DEI, Kicker, Polk Audio, Stinger sound system custom cold air intake, diamond plate floors, progress springs 2" drop
    Freakville Pc's
    The PT Crew
    my cardomain page
    my webshots page
    Constant Bitrate CHUPACABRA's Avatar
    Mar 2004
    G'ville S.C.
    You might want to spend the extra $30 bucks om a sound blaster mp3 (usb sound card)
    or a sound blaster live!LS.It sounds like you have a high power on board sound card like some HP computers have cause thay didnt come with amplified speakers only those polk stand alone ones.Now Im not talking like 100w here only like 5w maybe,I had that problem before and it was the onboard sound card giving to much power to the RCAs.
    5 watts is a lot to go through your RCAs.
    2-15" ILO lcd w/DVI
    6800 gt Duel DVI out
    p4 1.6ghz flex atx board
    1gb 400 ram
    120gb(2-60gb raid) sata hd
    2-60gb hotswap
    WIN2K Pro SP2
    M.A.M.E. w/2,300 games
    CARPuter info
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    First try lowering the gain on the amps. That should drop the noise level so much that you'll barely even notice it. Just make it loud enough for the quietest mp3 at about 80% volume and it'll sound great!
    May 2004
    NJ
    This will answer your last Q http://www.tmz.com/wrx/lilliputLCD.html, it is the color code and other stuff.
    Jan 2004
    Thanks for the help, I lowered the gains a little, that cured alot of the noise issues now i just have to tweak it. I plan on gettin another soundcard, i just had to use the on board sound for now.
    kingtut thanks alot for that pinout for the lilli
    2003 PT Cruiser
    Freakville Pc's
    The PT Crew
    my cardomain page
    my webshots page
    Feb 2004
    Spartanburg SC
    Solder a jumper wire between the PS2, Sound and other blocks on the back of the bord to ground. When a motherboard is used in a case the back panel grounds via fingers, by removing from case, grounds are non existent thereby causing hum in audio levels
  1. Volume Control Button Suggestion
    By sangsational in forum Media Engine
    Last Post: 08-03-2004, 12:09 AM
  2. Volume Control
    By storm in forum FrodoPlayer
    Last Post: 06-27-2004, 12:02 PM
  3. control volume
    By turbochris in forum General Hardware Discussion
    Last Post: 06-09-2004, 05:57 AM
  4. USB Sound Card with ASIO driver and volume control
    By tbdombrosky in forum General Hardware Discussion
    Last Post: 02-03-2003, 11:00 PM
  5. hardware volume control
    By ODYSSEY in forum General Hardware Discussion
    Last Post: 04-20-2001, 10:43 AM
