Page 1 of 4 1234 LastLast
Results 1 to 10 of 36
Thread: Installing Power Capacitors?
    DLe
    DLe is offline
    Constant Bitrate DLe's Avatar
    Mar 2004
    Hey guys,
    This is a total newb question but I just bought a 1 farad power capacitor but I'm not sure how to install it. I know that I need to feed a wire from the 12v+ to the 12v+ prong on the power capacitor, but what is the other prong on the capacitor for?
    I don't believe that it is for the 12v- (negative) terminal on the battery, but I'm not really sure because it could be.
    I was thinking that it the other prong was the output to the amplifier and the + was the input for the 12v+ terminal of the battery.
    Please help me! Thanks guys.
    Newbie TWBarrett's Avatar
    Aug 2004
    Seattle,WA / Atlanta,GA
    The Capacitor needs a power and ground just like your amplifier does. Feed it a 12v+ from your battery, ground it, then run a second wire from the 12v+ lead to your amplifier/distribution block/etc.
    Hope this helps!
    Carputer Progress Meter
    {[|-------------------]} 5%
    Research and planning.
    Car: 1991 Toyota MR2 Hardtop
    Stereo: Planet Audio TT4300 & TT1250D, Kicker Resolution RS6 (front) & RS5 (rear), Image Dynamics IDQ12V.2 D4 (2x), Sony CDX-M610
    DLe
    DLe is offline
    Mar 2004
    Quote Originally Posted by TWBarrett
    Hope this helps!
    THANKS TWBarrett! When you say "ground it" you mean to the chassis right?
    Aug 2004
    Yes, to the chassis.
    Maximum Bitrate DjBac's Avatar
    Jun 2004
    GREECE/Athens
    Don't forget to place the capacitor as close to the amp you can.. (the wire that goes from the capacitor to the amp should be really short)!!
    Jun 2004
    Bay Area, California
    and dont forget to charge it the first time, capacitors are dead shorts when they are completely uncharged, so you cna cause a HUGE spark, weld, or even make your cap explode if you dont add some resistance in there teh first time! we usually use a light bulb. when hte light goes out, the cap is charged!
    Aug 2004
    Err yea, two good points. Rule of thumb is, what, 18" max from cap --> amp? And you can use like a $4 test light from Shucks or any auto parts store to charge it.
    Aug 2004
    Houston
    I forgot to charge mines once. Lets just say I will never forget from now on. lol
    DLe
    DLe is offline
    Mar 2004
    I've never heard about charging capacitors...thanks guys.
    How does wiring a lightbulb charge a capacitor? Weird.
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    Yea please explain
  1. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 06:10 PM
  2. Replies: 7
    Last Post: 06-15-2004, 09:29 PM
  3. Install coming up... but Power questions
    By technopsych in forum Power Supplies
    Last Post: 04-14-2004, 07:16 PM
  4. Brief power loss between ACC and start
    By Destin in forum General Hardware Discussion
    Last Post: 01-26-2001, 10:12 PM
  5. HELP!! Power Supply wont supply power
    By Saab in forum General Hardware Discussion
    Last Post: 08-28-2000, 09:33 AM
