Results 1 to 6 of 6
Thread: Positive ground amp??!!?? (help?)
    cheap custom title JC-S60's Avatar
    Mar 2004
    Ghent - Belgium
    Question Positive ground amp??!!?? (help?)
    Dear guru's,
    does somebody know how to connect a positive ground amp (the factory volvo amp in my S60) to a negative ground audio-source (my carpc)?
    Will a ground-loop isolator help? If it would, is the soundquality affected by the isolator (please, only tell me if you heard the difference in real life with your own ears, not if you read it somewhere...).
    Thanks!
    Joachim
    Mar 2004
    Ghent - Belgium
    boink
    Maximum Bitrate Yuriy's Avatar
    Jun 2004
    Seattle
    I heard the difference. It's not that you lose quality while using thr ground loop isolator, more like some of the frequencies get weaker. For example, you will hear less tremble and your bass won't be as "jumpy" if you know what I mean. But I would not call it a loss of quality, you just have to tweak the equalizer settings on your PC.
    00 Saturn SL2, boosted @ 8 psi - CarDomain
    Newest install - my quickest ever
    My 2nd carputer - b4 I broke the touchscreen
    My very first carputer - voted the most ghetto
    Mar 2004
    Ghent - Belgium
    Thanks Yuriy. So there is a noticable difference...
    Since I still didn't get any confirmation that my problem will be fixed with one, I guess I'll put in another 4ch amp and use the volvo amp in my mobilhome, together with the volvo head-unit
    Low Bitrate Aksor's Avatar
    Mar 2004
    Ottawa, ON
    A ground loop isolator is nothing more than an audio transformer with a 1:1 ratio!
    The transformer isolates the two sources electrically so there is no ground loop.
    It all depends on the characteristics of the transformer and the build quality of the unit.
    laz
    Mar 2004
    Ghent - Belgium
    Thanks, but I already replaced the amp by a blaupunkt 4x50w.
    I will use the amp in my camper, together with the original Volvo HU.
  1. del
    By hanzacra in forum General Hardware Discussion
    Last Post: 11-27-2007, 03:41 AM
  2. People with NO HeadUnit, Recommand AMP!!
    By camsgs3 in forum Newbie
    Last Post: 07-26-2004, 07:38 PM
  3. Need some help with sending audio to stock amp
    By orangewhip in forum General Hardware Discussion
    Last Post: 09-04-2003, 02:21 PM
  4. Question: Arise psu: ground, neg, and pos.....?
    By Tony S in forum Power Supplies
    Last Post: 05-02-2001, 08:54 AM
  5. Alpine / PC Challenges all around...
    By acitrano in forum General Hardware Discussion
    Last Post: 11-10-2000, 08:45 AM
