Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Is 5.1 worth it?
    Maximum Bitrate cadence117's Avatar
    Feb 2004
    Charlotte, NC
    Is 5.1 worth it?
    just straight out, for the enviroment, cost, time, quality (considering mp3 format and such) results..
    is 5.1 sound worth it?
    mobo $130 ; 150wOpus-$200 ; 256mb pc2700 -$10 ; 120gb HDD 7200-$70 ; Lilliput TS 7"-$265 ; USB LAN-Free AR ; Rikaline 6010 GPS-$34 ; ShuttleXpress-$37
    Total = $746....Carputer = Priceless
    Variable Bitrate Superduck's Avatar
    Oct 2003
    Vancouver BC
    I suppose that's a difficult question for someone other than you to answer.
    It's really up to the individual user, I guess. A lot of people have brought up the thought that if you want to watch 5.1 movies, do so at home, where you can really enjoy them.
    I'd imagine that the majority of the time, the average person will just listen to MP3's, which typically don't do 5.1. I've got a couple of DVD's that have 5.1 encoded audio on them, but compared to the number of stereo MP3's, it's fairly small. I'd imagine for me, 5.1 would be a waste of time and money, though, to be honest, I'll probably do it anyway.
    Try looking into what it takes to get 5.1 to sound good in your car, then determine if it's worth it to you.
    Cheers,
    Kris
    How Much Horsepower Can I have And Still Go To Heaven?
    Jan 2003
    Ruston, LA
    I would like 5.1, but I'm going to live with 4.1
    Frodo
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    Well I have to say that for me i didn't care if it was worth it or not. I just did it becasue i wanted it. The way that i went was a tad on the expensive side but you can do it for cheaper.
    I bought the panasonic CYAC300 (which is made for the car)
    Seth bought the creative 5.1 external module http://www.creative.com/products/pro...sp?prodid=9468
    He says it works fine with his system... the only problem he mentioned was that it took 14v so he had to get a 12v-14v adapter (big whoop)
    All in all it is more for the "cool" factor than actual use. If you maybe watch movies in your car 1 a month then stereo is fine
    Low Bitrate mp31023's Avatar
    M-Audio Transit
    If you want to go with 5.1/DTS without and power problems try this http://m-audio.com/products/en_us/Transit-main-1.html. I am using it with the Panasonic CY-AC300ex and works perfectly. And it runs on USB 5v, no external power supply.
    Jan 2004
    California
    Hey i might get that. I was using the spdif port from the via but i was having trouble finding a quality coax to optical convertor
    Via Coax
    Quote Originally Posted by antimatter
    Yeah I have the a coax to optical converter and the M-Transit and the audio from the Transit is much cleaner than the converter. I am using it with the CY-AC300ex. Actually I bought an extra CY-AC300ex from ebay for spare parts for $100 bucks. The seller sold it because it would not power up. So I thought, Hey I work for Panasonic, I can take it in and get repaired with a discount. But I plugged in the controller and the brain and worked like a charm. I was thinking it could be the cables. Plugged in all of the cables and it still worked fine. $100 a good deal.
    cheap custom title JC-S60's Avatar
    Mar 2004
    Ghent - Belgium
    I've tested with a Creative Soundblaster Audigy 2 NX, which is a USB external 7.1 soundcard. Just tested 4 channels with a DVD and it really sounds great. I will put in a small amp to power the stock center speaker and a 400w amp for a sub to complete the system.
    To power the Audigy, I'll use a 5v power supply, used for an ipaq (as it sucks 1,25a @ 5v)...
    A nice feature (that I haven't tested though) is the possibility to upmix any stereo source to 5.1 (or 7.1 for that matter).
    Jan 2004
    California
    Quote Originally Posted by mp31023
    Well i ordered that transit thingy and i am hoping that it will work becasue it was damn expensive. I also don't like the idea of running a seperate USB sound card (essentially that is what it is), I am hoping that this willl alleviate my issues. I also have the M-Audio C02 and have had nothing but trouble. YYMV and do note that i bought this used off of ebay but what i have noticed is that it has very wierd power arrangements, it says 9v but the AC power adapter puts out ~16v (WTHell??) anyways i can get it to run when I power it off of the PSU but when i crank up the volume the sound begins to crack (WThell??).
    I also used the the cheap converter off of ebay. I bought it for like 20 bucks and it was pretty solid but the way that i had it powered (radio shack convertor) whenever i stepped on the brakes the sound would cut out for a milisecond. I think there are strange things going on with my electrical system that may attribute to this funnyness but i really hope this is the answer i have been looking for.
    Mar 2004
    Ghent - Belgium
    on a sidenote, antimatter, put a small cap in front of any device that acts strangely to power fluctuations/noise. It helps a lot!
    And does your power supply put out 16v when connected to the converter too? Those cheap supplies can drop very easely some volts under load.
  1. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 12:54 PM
  2. Car 5.1 Dsp Options Vs Pc 5.1 Dsp
    By port20 in forum Car Audio
    Last Post: 05-29-2006, 03:10 AM
  3. 5.1 and stereo
    By mbaratta in forum Car Audio
    Last Post: 05-25-2004, 08:09 PM
  4. 5.1 surround
    By cassio in forum General MP3Car Discussion
    Last Post: 12-06-2003, 09:00 PM
  5. 5.1 in a car?
    By chewtoy in forum General Hardware Discussion
    Last Post: 10-16-2001, 10:48 AM
