Page 1 of 7 1234567 LastLast
Results 1 to 10 of 63
Thread: Remote faceplate! turned out really nice, check it out
    Low Bitrate Sporttracguy's Avatar
    Jul 2004
    Puyallup, Washington
    Talking Remotely wired faceplate! turned out really nice, check it out
    well i just finished my remote faceplate. I used 2 cat 5 cables and soldered all the connections to wire it up. I mounted it inside the front A pillar because i plan to remove the stock radio and mold in a xenarc touchscreen when i money comes around.
    http://www.zjstech.net/~library/3675...late-light.jpg
    http://www.zjstech.net/~library/3675/faceplate-dark.jpg
    here is some info on my ride:
    http://www.cardomain.com/memberpage/674459
    I did run into one problem that im not entirely sure how to fix though. The faceplate was designed to pivot down when you wanted to insert a CD and when it would do that the faceplate would disconnect from the HU. THe problem is now that the faceplate is always connected to the HU it wont let me eject the CD because it thinks there is a faceplate in the way. Im not sure what the best way around this woudl be. maybe make some sort of disconnect in the wire? any ideas would be great, thanks
    For some side note info on the other items in the picture. I molded in a 8 inch kenwood touchscreen below the radio bezel that is connected to an xbox/DVD player and my kenwood GPS system.
    Aug 2004
    Houston
    nice! trail and error disconnecting each wire and make a switch?
    Jun 2004
    Quote Originally Posted by Sporttracguy
    sweet install.. I got to do that to mine, just to do it. i'm diggin it.
    Variable Bitrate wkolodny's Avatar
    DC
    Great job Ryan. Where did you put the head unit?
    Don't Fear The Gurkey
    Click here to check out My Setup
    Jul 2004
    for now the head unit is in the glove box, it sits at about 60 deg. and thats the max for factory specs,, i couldnt think of anywhere else to put it
    Raw Wave tbird2340's Avatar
    Oct 2003
    Poland, OH
    So your putting an additional LCD in the bezel or are you taking the kenwood out? Why so many LCD's??
    The remote head unit face looks sweet there...
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
    Nov 2003
    Olympia, WA
    Nice install. Hmmmm...you live kind of close to me...I live in Yelm....if I ever get the need to do that I know where I'm headed! :-)
    Low Bitrate KMorphosis's Avatar
    Aug 2004
    Faw from heyar...
    hmm.. i am about to do this too next week. My stereo has been stolen twice in 4 months. Couple ?s. U only could put your HU at a 60 degree angle? Is that because you still use if to play cds?
    Any reason u used cat5 cables to make the connection?
    if you create a disconnect in the wires, do you think that would fix the problem with ejecting the cd?
    Is your faceplate still removable or not?
    This is what I had in mind to do.
    I still had the HU minus the face, but it was shredded on the sides when they tried to steal it. What I have done is removed the original face holder including mounting clips and connector. That way I can remote mount the face and still have it detachable. I was then gonna hard wire from this peice to the new HU that I had planned on mounting verticle. I don't use it to play cds cause its connected to a 12 disk changer and XM. I am thinking that I will need an antenna extension cable.
    Any imput to help someone out?
    Nice job on it though. Just curious how you see it when you are driving?
    Could you use a cat5 coupler in your system. that way to disconnect your Face from the HU you could just unplug a set of the cat5 cables?
    Jul 2004
    Tbird2340
    Yeah, im molding in a xenarc touchscreen and connecting it up to a computer. why you ask? because i can lol.. to be honest i molded in that kenwood before i though about using a computer.. so now im stuck with kenwood products if i want to use that touchscreen for anything else than DVD or GPS. I would like to have a computer to run all my MP3s and just for the custom effect
    Gambit32
    Im back up in school in bellingham now, a little farther away lol,,
    KMorphosis
    I needed to mount it at 60 degrees or less because i do still use the CD player(well i will when i figure out how to eject the damn thing lol)
    I used the cat 5 eithernet cables because there were 10 wires in each cable and i needed those to connect to each contact on the faceplate and head unit,, i figured that was the best way to keep it clean and the less loose wires the better. i dont lose any quality with the wires and so far it works great.
    As for the disconnect, i sure hope so,, im still not sure how to do it yet though,, we will see
    The faceplate isnt removeable, its secured in there quite well,, i suppose if someone wanted to steal it they could,, i think their prime target would be my $1500 touchscreen in the console though lol. I have video survalence i set up at my apartment complex and a kick *** alarm so i think im alright for now,, i still need to tint my front windows though
    lets see, help,, i mounted the HU in the glove box so i didnt need an extension for the antenna but you may depending on where you decide to mount the head unit. I like the idea of being able to detach the faceplate, i never though of that. on mine that wouldnt work because the clips that hold the faceplate on arent connected to the front part, they are more intigrated into the head unit
    as far as how i see it when im driving, you would be suprised, the optics on that faceplate are awsome and i can see it from any angle with no problem or loss of quaity at all,, i was very suprised myself. Its easier to glance over and see it on my A pillar than it is to look over and down for the origional stereo anyway, just takes some getting used to,, i really like it so far
    Aug 2004
    Faw from heyar...
    What type a HU do you have?
    http://www.tigerdirect.com/applicati...8024&CatId=746
    this is what i was thinking for the disconnect for your face..
  1. Check out this awsome RF remote
    By inniss777 in forum Input Devices
    Last Post: 05-28-2004, 01:55 AM
  2. First post, some hardware questions (check these out)
    By Leitnin in forum General Hardware Discussion
    Last Post: 04-06-2004, 02:34 PM
  3. ps2 pelican remote w/ creative reciever & girder
    By ShinkunoNamida in forum Input Devices
    Last Post: 04-26-2003, 03:00 PM
  4. Great ir remote to control mp3car
    By rcpirate in forum General Hardware Discussion
    Last Post: 10-16-2002, 01:01 AM
